LibLathe - Lathe Path Generation
dubstar-04
Re: LibLathe - Lathe Path Generation
Post by dubstar-04 »
Ramyashree wrote: Sat Jan 29, 2022 8:48 am I'm facing issue while adding profile, rough and part off operation to model body and getting following error. Please help me to resolve this issue.
The changes required to make the tools work were already queued as a PR. I have just merged that PR with a very quick test and it seems to work now.
If you pull the latest code from Github and try again it should work. See attached file.
Thanks,
Dan
chess pawn sketch.FCStd
(35 KiB) Downloaded 106 times
Ramyashree
Post by Ramyashree »
Thank You so much sir!!! It worked for me. :D
dubstar-04
Ramyashree wrote: Wed Feb 02, 2022 5:49 am Thank You so much sir!!! It worked for me. :D
That's great!
Thanks for letting me know.
Dan
warthog656
Post by warthog656 »
Hello everybody!
I'have a question, is-it possible to have the programm in "diameter" instead of "radius".
Is there an "argument" or a modification to apply?
Thanks!
CHARLYROBOT CRA2 / DENFORD MIRAC
dubstar-04
warthog656 wrote: Tue Feb 22, 2022 8:17 am Hello everybody!
Thanks!
No at the moment.
It is planned: https://github.com/dubstar-04/LibLathe/issues/139
Thanks,
Dan
runryder
Post by runryder »
I loaded liblathe on freecad .20. Can you give me some direction on why I'm getting this error message. It doesn't matter what operations I use.
I used your test file and I am able to see the paths but I unable to create my own
Window 10, freecad .20, latest version of liblathe
OS: Windows 10 Version 1809
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
* A2plus 0.4.56a
* Assembly4 0.12.0
* Curves 0.4.4
* fasteners 0.3.45
* FeedsAndSpeeds 0.4.0
* FreeCAD_Turning_Addon-master 0.1.0
* Manipulator 1.4.5
* sheetmetal 0.2.49
* ThreadProfile 1.81.0
'Path_TurnFace' failed:
File "C:\Program Files\FreeCAD 0.20\Mod\Path\PathScripts\PathOpGui.py", line 1427, in Activated
return Create(self.res)
File "C:\Program Files\FreeCAD 0.20\Mod\Path\PathScripts\PathOpGui.py", line 1378, in Create
obj = res.objFactory(res.name, obj=None, parentJob=res.job)
Create() got an unexpected keyword argument 'parentJob'Running the Python command
Thanks for the help
liblathe error code.txt
(11.11 KiB) Downloaded 68 times
Post by Kunda1 »
@runryder welcome to the forum. Can you please edit your post and attach your full About info. This will tell us the full FC version and the liblathe version you have installed.
WarrenkCash
Post by WarrenkCash »
I was getting the same error as runryder. The fix for me was to edit PathOpGui.py. I changed line 1378 lo read as below
obj = res.objFactory(res.name, obj=None)
For my system the path to the file was /home/warrenkcash/snap/freecad/common/Mod/Path/PathScripts/PathOpGui.py
I also found the square tool (Iso_shape_S) had to have the Tip Angle set to 89.999 not 90 or a tool path would not generate.
I have been able to create a job and add all the turning paths the job. It is not finished but I will attach What I have so far.
All in all I think Daniel Wood has done a top job and I would like to say thank you for the effort he has put into this addon.
I will be testing this more should I start a new thread or add to this one?
OS: Ubuntu Core 20 (X-Cinnamon/cinnamon)
Version: 0.20.29177 (Git) Snap 161
Branch: tag: 0.20
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.2
Installed mods:
* Start
* Material
* Show
* Import
* SnapSetup
* AddonManager
* Tux
* Path
* Part
* MeshPart
* Points
* Robot
* LibLatheOLD
* LibLathe-masterOLD
* Idf
* Web
* pyserial-master
* Surface
* Arch
* Raytracing
* TechDraw
* serial
* Plot
* Drawing
* Image
* PartDesign
* Fem
* Test
* Inspection
* Mesh
* Measure
* Spreadsheet
* Draft
* Sketcher
* OpenSCAD
* ReverseEngineering
YZwheelSpacer.FCStd
(73.71 KiB) Downloaded 59 times
Post by Kunda1 »
WarrenkCash wrote: Wed Jul 27, 2022 4:20 am I was getting the same error as runryder. The fix for me was to edit PathOpGui.py. I changed line 1378 lo read as below
Would you be open to making a Pull Request?
WarrenkCash
I will look into it and give it a go. I will be asking for help if I get suck.
