LibLathe - Lathe Path Generation
dubstar-04
Re: Lathe Features
Postby dubstar-04 » Tue Feb 26, 2019 1:59 pm
JoshM wrote:
Sat Feb 23, 2019 6:44 pm
Hi Dan,
Attached is a model representative of a typical mixed lathe/cnc job, to play with.
It's largely a lathe job, but has other features that make it not entirely symmetrically radial.
Best,
Josh
Thats perfect. Thank you.
JoshM
Re: Lathe Features
Postby JoshM » Tue Feb 26, 2019 2:06 pm
Hi Dan,
Glad that works for you. I'll try to come up with more models for you to work with.
On G94, what I meant was that GCode allows movements that are absolute--ie. G0X0Y0F100--and relative to time (Feed Rate). G94 shifts it from distance per unit time feed rate to linear distance moved per rotation of the spindle. I'm aware of this, and have used it for threading, but was asking how that element of the overall work-flow fits in--in your plan.
Best,
Josh
JoshM
Re: LibLathe - Lathe Path Generation
Postby JoshM » Wed Feb 27, 2019 11:05 pm
Here's another job model to test against.
Lathe_Job_001.FCStd
(12.34 KiB) Downloaded 45 times
Ks_Programmer
Re: Lathe Features
Postby Ks_Programmer » Sat Mar 16, 2019 12:35 am
Hi Dan,
Best,
Josh
On my HAAS ST10, G94 is a canned cycle for "End Faciing", G98 is Inches per minute, & G99 is Inches per Revolution. Just info...
Regards, KP :geek:
dubstar-04
Postby dubstar-04 » Thu Aug 15, 2019 8:40 am
I'm on holiday this week so i managed to find time to continue work on liblathe.
Screenshots below show basic profiling and facing OPs.
Its certainly not production ready but as a proof of concept its very encouraging.
Just need to find time to continue working on it... :cry:
Postby Kunda1 » Thu Aug 15, 2019 12:41 pm
awesome!
RatonLaveur
Postby RatonLaveur » Fri Feb 14, 2020 6:55 am
Hello gents,
I recently shifted my interest back to turning operations.
I've already experimented with Sliptonic's 4th axis mapping for milling, but now the full turning is catching my eye on the 5 axes.
Is there a prototype or macro of your work that i could test?
dubstar-04
Postby dubstar-04 » Fri Feb 14, 2020 9:17 am
Hello gents,
There is a liblathe branch of FreeCAD here: https://github.com/dubstar-04/FreeCAD/t ... ntegration
Not really got anything useable at the moment, however, I will be continuing this work later this year.
If you could give me a nudge ever few weeks that would be awesome! :lol:
RatonLaveur
Postby RatonLaveur » Fri Feb 14, 2020 3:18 pm
Hey thanks, as much as I'd like to see a working solution in FreeCAD, I will most definitely not nudge you. Not until I learn to code myself ;)
Thanks for all you do.
