In Face operation the Material Allowance parameter is not taken into account using
Line, Grid, Triangle patterns. The same problem exists with Pocket Shape operation regarding Pass Extension parameter.
The attached patch might fix the behaviour. The path operations in the attached model were done with the applied patch.
OS: Linux
Version: 0.18.14993 (Git)
Build type: Debug
Hash: 1e6818b6fbf86ad08d8fc85252dddcae8891dd54
Python version: 2.7.15
Coin version: 3.1.3
OCC version: 6.9.1.oce-0.18
Face operation (Pocket Shape operation), Material Allowance (Pass Extension)
- patch.txt
- (1.02 KiB) Downloaded 47 times
- offset.fcstd
- (33.61 KiB) Downloaded 34 times
Re: Face operation (Pocket Shape operation), Material Allowance (Pass Extension)
OP created a issue #3665 because they didn't get any feedback from the community. Anyone willing to test this and the patch ?
BTW, why are you still using a very inferior OCC version ? Where did you install FC from ?
I have downloaded the source form GitHub using git. Open Cascade came as a package on Fedora 27.
- sliptonic
Thanks for the patch and the issue. I've been out of pocket for a bit with some family stuff. The patch looks good to me but I haven't actually tested it.
jurij, if you're comfortable with git, go ahead and do a pull request for the change. If not, I can do one.
Does Fedora Rawhide have a more up to date OCC? Anyway, you will experience known issues not upgrading at least to 7.2
edit: perhaps you can talk to the fedora occ packager to update the package ?
Hi sliptonic,
I am not familiar with git so if you find the patch useful I would be grateful if you could integrate it.
Hi Kunda1,
I have looked for the OCC library version in the latest Fedora 29 and also Fedora Rawhide.
They both use the latest opencascade community edition ( https://github.com/tpaviot/oce ) which is based on OCC 6.9.1 .
Also FreeCAD 0.17 package in the latest Fedora is linked to that library. I think that Fedora doesn't use official OCC library.
Hi Kunda1,
