One job, multiple operations returning to origin between operations
stylesuxx
Postby stylesuxx » Thu Feb 14, 2019 10:28 am
I have searched but could not find anything - maybe I use the wrong terminology, if this has been answered already please feel free to link me to the according post.
I am in the path view, added a job. This job consists of two operations, a pocket shape and a contour.
After the pocket shape operation is done, the tool returns to the origin, then back to the entry of the pocket shape and then moves to the entry point of the contour.
I was wondering if there is a setting that allows me to directly move the tool to the entry of the contour once the pocket shape is done, instead of returning to the origin first.
I hope you can understand what I mean - if not, I could upload a screengrab from the simulation.
I am using Freecad version 0.18
heart.fcstd
(24.85 KiB) Downloaded 6 times
Re: One job, multiple operations returning to origin between operations
Postby chrisb » Thu Feb 14, 2019 1:15 pm
Moved to Path forum.
Postby chrisb » Thu Feb 14, 2019 1:22 pm
You can try using different start points.
stylesuxx
Postby stylesuxx » Thu Feb 14, 2019 1:46 pm
Thank you for your answer - that was one of the things I tried but the tool is still moving to the origin before moving to the starting point and executing the cut.
herbk
Postby herbk » Thu Feb 14, 2019 1:59 pm
you don't have to do anything - the first red line is only shown at the screen.
At the machine, the tool starts "where it is" and go's to "save height" -> "start of milling". If your first path is finish, the tool returns only to "save height", X /Y "where it is". From there it go's to start point of the secound path.
If you take a look at the gcode, you will notice this behavior.
Gruß Herbert
stylesuxx
Postby stylesuxx » Thu Feb 14, 2019 2:13 pm
Oh, you are right - thank you. Now I feel like an idiot for not having looked at the gcode.
Danke.
