I search first but nothing found.
I build opencamlib and python extension so if i run python2.7 and import ocl everything works good.
then i download appimage FreeCAD_0.18.15860.glibc2.17-x86_64.AppImage and run it.
But i cant enable Path experimental function , i want [PATH] 3D surface
so if i run python console and then try import ocl , it is a problem.
so what can i do ?
add ocl to appimage ?
opencamlib and AppImage experimental function
- freecad.png (50.15 KiB) Viewed 1155 times
Re: opencamlib and AppImage experimental function
So i extract appimage (squashfs) and add into it opencamlib (python and base library )
So now i can import ocl without any errors in Freecad but cant enable path experimental function (in parameter editor switch is missing)
In image u can see import ocl without any error but [PATH] 3D Surface missing
- freecad.png (154.3 KiB) Viewed 1151 times
I do not believe there is a standard user interface to add the experimental features.
Just create it yourself. Right click in the Path parameter area and select New Boolean Item. Call it:
EnableExperimentalFeatures
and set to true.
Gene
and set to true.
Gene
this is working perfectly
thank u so much
thank u so much
Probably repackaging the appImage? https://www.freecadweb.org/wiki/Appimag ... t_Workflow
