Selection of faces very slow in Path Workbench
daniel_cnc
Postby daniel_cnc » Sat May 18, 2019 7:38 pm
I have a rather complex Project.
I have 4 Bodies and i have cloned them, so I can move them in one plane for cnc milling.
What I have detected is that selection of faces is very slow.
When I click on a face i have to wait seconds before I can select the next one. This only happens in Path workbench.
If i switch to Part for example selection is fast as expected.
Does Path add some calculation on select?
Mfg Daniel
sliptonic
Re: Selection of faces very slow in Path Workbench
Postby sliptonic » Sat May 18, 2019 8:30 pm
This isn't necessary. When you select the bodies during creation of the the Job, path makes a copy of them anyway. At the same time, you can use the job setup dialog to move the copies into cutting plane and position them. The copies are hidden when you exit the job setup dialog and the originals are reshown.
It might be that with your setup, you're job setup is now handling copies of copies. If you can share your model, it would be easier to diagnose. Also, whenever asking for help on the forum, it's good form to include your FreeCAD info (help->about and use the button to copy your details to clipboard so you can paste them here).
daniel_cnc
Postby daniel_cnc » Mon May 20, 2019 7:28 pm
Hello sliptonic,
Thank you for your anwser.
Yes I forgot to include my freecad Version. I could not edit after I posted. :-)
Good too know that path creates copies. But Can I Add Multiple bodies to one Job?
I don't want to create Muliple Jobs that would take much more time to create.
I testet it with the latest 0.17 and 0.18 Version
OS: Ubuntu 18.04.2 LTS
Version: 0.18.16110 (Git) AppImage
Branch: (HEAD detached at 0.18.1)
Python version: 3.6.7
Qt version: 5.6.2
I will attach the file.
https://www.dropbox.com/s/ilub5r4170usb ... fcstd?dl=0
I hope you can access this Dropbox link
Mfg Daniel
m0n5t3r
Postby m0n5t3r » Mon May 20, 2019 8:42 pm
Confirming that face selection is weirdly slow in this particular file, even after setting refine=true on the source objects (so the face count gets reduced drastically) in the latest 0.18
It also brings up an interesting problem: if you choose the top face for "profile faces" and select "process holes", the slot-like pockets get profiled all the way down; if you select the bottom faces, it looks mostly ok, but it also selects some round holes for profiling for some reason (with "process holes" enabled and "process circles" disabled); I guess edge profile would be the most flexible method, but it's incredibly tedious, so maybe a way to pick which "holes" to profile would be a good idea, or double-clicking an edge when selecting for edge profile could select all connected edges...
can you check if selecting faces is slow in this file? It has similar complexity and more faces to choose from: https://matrix.m0n5t3r.info/_matrix/med ... wZEPOqrRbi (and it's fast for me)
Postby chrisb » Mon May 20, 2019 11:29 pm
The View property "Deviation" is set to 0,01, a rather small value. That can make the display rather slow.
daniel_cnc
Postby daniel_cnc » Tue May 21, 2019 6:45 pm
@m0n5t3r Thank you for that hint found out how to activate the refine afterwards.
When I try to remove a mirror from my Multitransform I get a nasty crash. I will post that in another Thread.
@chrisb Where is that property?
OK I used Refine and got rid of my clones did not know That I can add multiple bodies to on Job must be new.
After all this tweaks it runs fast now.
Like it better like this.
The only thing is left now, is to select a bunch of holes to mill them :-)
Hope this will get better in the future.
Postby chrisb » Tue May 21, 2019 6:56 pm
Preferences->Part Design->ShapeView
and in the View properties, which you see by switching the lower tab of the combo view.
daniel_cnc
Postby daniel_cnc » Tue May 21, 2019 7:05 pm
Thank you, mine is 0.5. After i saved with 0.18.
But in my original file it was 0.1. But chaning that didn't made any difference in the orig file.
But I will keep that in mind for the future.
