Bug in Path/Pocket 0.19
scholli
Postby scholli » Sun May 19, 2019 11:27 am
I found a strange behaviour in the latest daily (which I could not find described anywhere yet).
When I try to create a pocket operation the basemodel jumps out of it's position (even kind of random as it seems)
Bildschirmfoto von 2019-05-19 13-16-50.png (182.46 KiB) Viewed 1082 times
I attached the test file with which I was able to reproduce it...
Hope that helps finding the root cause an fix it.
OS: Ubuntu 18.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Python version: 3.6.7
Qt version: 5.9.5
testPocket.FCStd
(38 KiB) Downloaded 23 times
roerich_64
Re: Bug in Path/Pocket 0.19
Postby roerich_64 » Sun May 19, 2019 3:26 pm
Hi Scholli,
With this version it is ok:
OS: Windows 7
Version: 0.19.16274 (Git)
Hash: 7c760259a389b38b76da78e4f6e1f9be66714842
Python version: 2.7.14
OCC version: 7.2.0
With the other versions i have tested we have an issue with the pocket operation on faces:
Py2:
OS: Windows 7
Version: 0.19.16784 (Git)
Hash: ec5720d51c54e6c433cacf207e773aad09dbb25c
OCC version: 7.2.0
Py3:
OS: Windows 7
Version: 0.19.16624 (Git)
Hash: 222ae7305fdf1097e4ef3d050f69dff47dbd8786
Python version: 3.6.6
Qt version: 5.6.2
OS: Windows 7 SP 1 (6.1)
Version: 0.19.16699 (Git)
Hash: e484a52e9d4ccaa360952cd8755b4a8ee6ad2ea1
Python version: 3.6.8
Qt version: 5.12.1
Qt version: 5.12.1
BR
Walter
mlampert
Postby mlampert » Sun May 19, 2019 4:21 pm
Yes, this is currently broken - it happens whenever one repositions or rotates the base model. Unfortunately the fix is not straight forward and will probably take a bit.
Postby chrisb » Sun May 19, 2019 4:58 pm
Here it is even worse, perhaps due to the fact that openCamlib isn't installed:
After a fresh FreeCAD start and loading the model I get the error in report view
OpenCamLib is not working!
A recompute shows the message
PathPocketShape.ERROR: Pocket does not support shape Model-Body001.Face11
and then the path vanishes completely.
OS: macOS 10.13
Version: 0.19.16790 (Git)
Hash: 15f440525e59c3caf89f847a490981abf5a45f8f
Python version: 3.7.3
Qt version: 5.6.2
Russ4262
Postby Russ4262 » Tue May 21, 2019 4:40 am
Evening,
I am taking a look at this issue. I have downloaded the model file in the OP. I have identified one problem in the model file. I have not been able to reproduce the result in the model file, yet. I will also test with earlier releases when I have additional time. I will provide more information and solution when it is not so late here.
Stay tuned,
Russell
OS: Windows 10 (10.0)
Version: 0.19.16793 +19 (Git)
Branch: 4th_axis
Hash: 8fd03fd529b1e6ba15aacd4898291b95cfbe09dd
Qt version: 5.12.1
roerich_64
Postby roerich_64 » Tue May 21, 2019 6:46 am
Hi Russel,
Do you need a step by step to see where the error occurs?
I can reproduce it...
Edit: Wait, i am download the newes version of FreeCAD...
Walter
roerich_64
Postby roerich_64 » Tue May 21, 2019 8:18 am
Ok with:
Version: 0.19.16808 (Git)
Hash: 0e17c22e3995693e1e329ee18af8c972a81fe831
Qt version: 5.12.1
Start here:
* Create Path Operation
* Take 'SETUP'
* Click on Face4
* Click on 'Z-Axis
* Click on 'Z=0'
* Click on 'Refresh' to refresh the stock
* Click 'OK' to close Setup
* Click on 'Canvas' to deselect 'Face4'
* Select Face11
* Click on 'Create Path Pocked Object'
* Click 'recompute'
* Click 'OK'
* doubleClick on the 'Job' in the tree
Now we see this:
Error massage translation (Gxxxle): PathPocketShape.ERROR: The bag does not support the form Model-Body.Face11
Russ4262
Postby Russ4262 » Mon May 27, 2019 3:47 am
Evening,
Thanks for the instructions above, Walter.
Ok with: ... Start here: ... Now we see this: ... PathPocketShape.ERROR: ...
Using them, I was able to reproduce the error and trouble-shoot the problem.
I collaborated with @mlampert and have corrected the issue. ...Well, at least the current model works correctly. However, I have since made additional modifications to the same files to accommodate rotational UI elements. So, I have two options:
  1. wait to present the solution as a part of my next PR
  2. use the current scripts to make patched versions with only the necessary changes to address the issue identified in this topic - then upload to the related topic here on the forum
If I get time, I may opt for making a patched version of the current script. This would help FC users sooner. Besides that, I don't have a time frame for my next PR with 4th-axis UI integration.
Thanks.
Russell
Russ4262
Postby Russ4262 » Sat Jun 01, 2019 5:52 am
Morning,
Okay. I reworked the script. So far my tests show this behavior to be eradicated. Further testing will confirm or disprove the fix... lol.
I appreciate the testing and feedback.
Please visit the Path Pocket Shape: 4th-axis Integration topic to download the updated scripts to fix this issue. You will need to re-create your Path Pocket Shape operations because the "Use Rotation" property has been renamed to "Enable Rotation" in preparation for UI integration of rotation settings within the core of the PathWB.
roerich_64 wrote:ping
Thanks Walter for the help in reproducing the error.
I think it is fixed, unless there is another issue to which you were referrring? I ran a couple tests on the two instances of this problem reported here in the forums and both models and operations behaved correctly with the fix. I have this fix already in my 4th_axis branch - had to edit it in order to remove UI elements I had installed also. Stand-alone version 1k-testing is available now at the topic linked above. Feel free to visit my GH repo and build the 4th_axis branch that has Rotation UI integration for PathWB well started.
Russell
RatonLaveur
Postby RatonLaveur » Sat Jun 01, 2019 4:19 pm
Shall we mark as solved based on Russ's new published python scripts?
