pot purri of path issues
Erich Schulz
Postby Erich Schulz » Tue Jul 02, 2019 7:34 am
Heya
This could be quite curly...
So I've made myself a parametised pin-board. The number of pins and size of the board is driven from a spreadsheet.
Now I'm trying to make a path (something I'm just starting to play with.
several issues.
Firstly when I a make the job the model clone fails to fully represent the multi-select (so rather than having a grid of holes, the path model onlyl has the first column)
Secondly at one point I had a very hard time getting one of my paths to dissapear - setting the operation to invisible or even the job to invisible failed to hide it. Eventually I saved and reopened the file a few times and the paths dissapeared.
Finally when I selected a few of my holes and tried to make a drill operation I got the following err
Drilling Select Mode
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathOp.py", line 270, in onChanged
    self.updateDepths(obj, True)
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathOp.py", line 382, in updateDepths
    fbb = base.Shape.getElement(sub).BoundBox
<class 'Part.OCCError'>: NCollection_IndexedMap::FindKey
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathOpGui.py", line 172, in updateData
    self.panel.updateData(obj, prop)
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathOpGui.py", line 963, in updateData
    page.pageUpdateData(obj, prop)
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathOpGui.py", line 493, in pageUpdateData
    self.setFields(obj)
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathCircularHoleBaseGui.py", line 84, in setFields
    item = QtGui.QTableWidgetItem("{:.3f}".format(obj.Proxy.holeDiameter(obj, base, sub)))
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathCircularHoleBase.py", line 110, in holeDiameter
    shape = base.Shape.getElement(sub)
    self.setFields(obj)
    self.setFields(obj)
    self.setFields(obj)
OS: Ubuntu 18.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.9.5
I'll keep playing but thought I'd share the little experiences in case anyone can make anything of them... especially after advice on the first issue.
pintable.FCStd
(57.71 KiB) Downloaded 18 times
Russ4262
Re: pot purri of path issues
Postby Russ4262 » Tue Jul 02, 2019 11:08 pm
Mr. Schultz,
Your version number is truncated at the major release, 0.19. This seems to happen regularly on some Linux distros. Please provide us with the minor version number so we can better assist.
Also, if you have a list of steps used to reproduce the error, we would appreciate it.
Thanks,
Russ
kkremitzki
Postby kkremitzki » Tue Jul 02, 2019 11:19 pm
It's probably the daily builds PPA. You can make sure you have a recent version by checking the output of dpkg -l | grep freecad-daily.
quick61
Postby quick61 » Wed Jul 03, 2019 11:55 am
The last couple of days, the Path workbench in the PPA Daily builds has been broken. (at least here it has) When trying to start a new path job, Creates a new path job object, I get...
Running the Python command 'Path_Job' failed:
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathJobCmd.py", line 71, in Activated
    dialog.setupModel()
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathJobDlg.py", line 90, in setupModel
    self.candidates = sorted(PathJob.ObjectJob.baseCandidates(), key=lambda o: o.Label)
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathJob.py", line 395, in baseCandidates
    return sorted([obj for obj in FreeCAD.ActiveDocuemnt.Objects if cls.isBaseCandidate(obj)], key=lambda o: o.Label)
module 'FreeCAD' has no attribute 'ActiveDocuemnt'
...and yes, the daily PPA builds don't have a revision number, haven't sense day 1 of the 0.19 build cycle. Either it's a problem that can not be fixed, or no one has bothered, don't know. I have just been using the build date, which is in the Help > About but dose not get copied to the clipboard, so one has to type it in manually.
** Release date 2019/07/02 21:54:33 **
OS: Kubuntu 18.04.2 LTS (KDE/plasma)
Version: 0.19.
Qt version: 5.9.5
sliptonic
Postby sliptonic » Wed Jul 03, 2019 2:59 pm
Fixed with PR #2317 merged this morning.
Russ4262
Postby Russ4262 » Wed Jul 03, 2019 8:20 pm
...Firstly when I a make the job the model clone fails to fully represent the multi-select (so rather than having a grid of holes, the path model onlyl has the first column)
I did verify this problem. I would say it is a bug in the clone tool/command, if I had to guess. This is independent of the PathWB. This is verified by going to the `Part` workbench, selecting the `Body` in the object tree, and running the `Part-->Create simple copy` command. The copy is created, but lacks all the holes as desired.
We'll have to investigate or test a little more to pin down the exact bug to report.
On the other hand, you can achieve the same pin/peg board layout with work arounds to the `Multitransform feature` tool. If you would like some assistance getting to the same result, let me know. Once you get the new version of the pin board, PathWB should handle it well.
Thanks for the feedback.
Russ
Russ4262
Postby Russ4262 » Thu Jul 04, 2019 3:28 am
Had a some time this afternoon. Put together your pin-board with alternative CAD tools since the PartDesign-->Multitransform Feature did not work as intended.
I attached the model file and a screenshot. You've got two options for creating the holes: Drilling, or use Profile Faces with `processPerimeter` flag off.
Have fun.
Russ
pintable_2.FCStd
alternative CAD tools to create pin-board
(80.93 KiB) Downloaded 9 times
result with 2 options for holes
herbk
Postby herbk » Thu Jul 04, 2019 7:14 pm
Hi Erich,
btw: for drilling this holes you don't need to do it that way... If you make only one hole into your sheet, create a drilling operation for this hole and use the Path Array for the repeats... It saves a lot of calculation time... ;) ;)
Gruß Herbert
Postby chrisb » Fri Jul 05, 2019 10:24 am
Some posts from this topic where split to wiki subforum. Splitting topics that go over more than one page is a difficult task, authors please veryfy that I was successful.
Chris
Erich Schulz
Postby Erich Schulz » Fri Jul 05, 2019 9:50 pm
Chris
Thanks!
Hi Erich,
Wow. that's an intriguing work flow. The being able to generate parts based on paths could be much simpler than attempting to generate efficient paths based on parts I am thinking. It also has the benefit of allowing quirks of the milling process to potentially become "features"... It's not really calculation time ththat worries me as much as machine time (noise, power, wear etc)
