is related to a few of my other posts. I'm hoping that my status as a complete noob stumbling around in the darking and bumping into things is kinda helpful and not too irritating. Freecad is truly awesome so I would like to be helpful.
and I am quite confused as to when I would choose each - I'm pretty sure I get the difference between helix and drilling but as the rest I'm only guessing (and based on efforts to date, guessing poorly!)
Path-CompleteLoop.png Complete Loop: Completes a loop from two selected edges
Path Contour.png Contour: Creates a path of the contour of the base object
Path-Profile-Face.png Profile from Face: Creates a profiling path from a selected face
Path-Profile-Edges.png Profile from Edges: Creates a profiling path from selected edges
Path Pocket.png Pocket: Creates a pocketing operation from one ore more selected pocket(s)
Path Drilling.png Drilling: Performs a drilling cycle
Path-Engrave.png Engrave: Creates a engraving path
Path-Face.png Mill Face: Creates a surfacing path
Path-Helix.png Helix: Creates a helical path
Path-3DPocket.png 3D Pocket: Creates a path for a 3D pocket
I'm all for making any of the tooltips, class and method comments more expressive. Anything that I wrote could definitely need refinement - to put it mildly.
If you create a PR for these with better texts that would be awesome!
mlampert wrote: ↑Tue Jul 16, 2019 8:47 pm
cool
perhaps if we start work on the wiki page? if we can get that a bit clearer I am happy to do PR on the tool tips
I am especially confused by the terms "facing" and "contour path" and difference between a "path packet" and a "path 3d pocket"
what would be really useful would be some bigger thumbnails of a before and after (or maybe a set of before and afters) showing what each operation does
While this topic is open, there is one aspect of redundancy that i feel may be worth addressing, profile based on faces and profile based on face or faces.
I think the two tools could be merged into one and an if statement based on the selection (e.g. If face is selected profile based on face, if edge loop selected, profile based on edges). With the error message in the task panel appearing if the selection is confusing.
(e.g. If edge selected but not full loop, ask for loop. If edge and face both are selected ask to choose either or...etc).
It is possible that the deburring operation actually does the same thing, after all, deburring is profiling with no step down around one or several edges. One would have to select the right tool and tool controller for it however. Or it could be a drop down menu....
This actually echoes to some extent Russ's suggestion that 3D pocket might actually just be the merged pocket operation.
Or maybe all these tools are sufficient as they are and there more interesting fishes to fry (most likely a true statement).
It does seem like we have too many choices. Simplifying the UI and letting the code select the algorithm based on dropdowns within the operation definition.
