Can't engrave text!
Can't engrave text!
Hi all,
My set up is:
OS: Windows 10 (10.0)
Version: 0.19.17337 (Git)
Hash: 0871fb49c71f1ac4029e441814332368f42bd78a
Python version: 3.6.8
Qt version: 5.12.1
I have attached a very small file where I have a shape string I wish to engrave, using a mill face operation to try and remove all the material within the character outlines. Currently I have an engraving tool selected. The font is a san serif with uniform line thickness. The text is not that small, and no matter what cutting pattern or tool I choose, the simulation shows that it is only sporadically cut. I'm getting very bewildered trying to understand the complete failure of this operation. Where can I get more information on how the cutting algorithms work (without reading the python source ) Or, can someone explain what's happening, and what I can do instead?
Thanks in advance - Frank
My set up is:
Qt version: 5.12.1
- TextPath2.FCStd
- (187.27 KiB) Downloaded 31 times
Re: Can't engrave text!
Hi Frank
your letters are pockets, so if you use the pocket OP it works.
Edit: The "S" don't work, i can't figure out why atm...
Edit edit: If i use "Profile by Edges" i got a path for the "S" to, but it should work with Poket op to.
Gruß Herbert
I'm sorry, but it's not at all accurate. Below is the result of running the simulation (as you can see, much is missing) :
here it works with FC 0.18.2 edit: not with 0.19
- TextPath_herbk.FCStd
- (285.76 KiB) Downloaded 23 times
Gruß Herbert
Afternoon, Gentlemen.
I can verify the problem with PathPocketShape. I downloaded falviani's file in the OP.
The 'S' will not produce a path using PocketShape. I attempted it within a grouped Base Geometry operation and a operation where the 'S' face is the only Base Geometry. PathPocketShape is quite slow now, compared to earlier FC 0.19 releases around the 16700 minor range.
I also noticed the Apply/change-setting relationship in the task window editor is not working correctly.
Steps to reproduce:
Version: 0.19.17352 (Git)
Hash: ec0049921b813ee78c1fd4ea304e70904a3208f7
Qt version: 5.12.1
Steps to reproduce:
- Select faces for the 'T' and 'E'.
- Create the PocketShape icon and click 'OK' with no changes.
- Double click the new Pocket_Shape operation to edit.
- The 'Apply' button is inactive. (Normal behavior)
- Change the Step Over Percent and the Pattern.
- The 'Apply' button remains inactive. (Problematic behavior)
Qt version: 5.12.1
Thanks for the update. I downloaded version 352 and tried the simulation again, with unchanged results. My expectations were that the end result would match the pocket. I deliberately made it quite shallow so that the significant taper in the tool profile would (hopefully) result in a very small allowance for the tool radius. Perhaps the code can't handle a tapered tool and just assumes the diameter in the controller (which in this case is 3mm)? If so, I would consider that a bug.
If I substitute a 1mm endmill for the engraver, I get the expected results.
Again, thanks - Frank
If I try to edit the tool Engraver1 with a double click, FreeCAD crashes. Can somebody confirm?
OS: macOS High Sierra (10.13)
Version: 0.19.17360 (Git)
Hash: 348160d4ea970f5f6d0850272c04800c0222c8ba
Python version: 3.7.3
Qt version: 5.9.7
Locale: English/Germany (en_DE)
Qt version: 5.9.7
The missing path seems to come from too big a tool:
Tool diameter 2.81: .
Tool diameter 2.82:
Tool diameter 2.82:
Not realy... If i use FC 0.18.2 from OpenSuse Repo, the 2mm tool and try to create a path with "Pocket OP" it don't work. Profile on face and Profile at edges works.
If i do the same with the latest 0.19 AppImage FC crashes if i try to get a path for the S. - on each OP...
The crash at doubleclicking the engraver to edit i don't have at both.
Gruß Herbert
Thanks for reporting back. I will try some comparisons of 0.18 and 0.19.
