[Merged] MillFace: add feature - exclude raised areas PR #2367
Russ4262
Post by Russ4262 »
Morning,
MillFace needed(okay, would benefit from) this new feature: [Path] MillFace: add feature - exclude raised areas. You know you wanted it in the past. Here it is. "Exclude Raised Areas" is the new property to enable the self-titled feature. Pockets (holes, depressions, slots, etc...) are still milled over as expected; but, enable the new feature and that raised stud in the middle of the face will be excluded - left alone - not touched - safe - a tree in the midst of a milled plateau. Okay, you get the idea...
If not, I attached a few pics: before and after.
The new feature does NOT include avoidance detection. So, raised areas that are slanted out, angled out, bulging out, have overhangs pointing outward, etc... will not be adjusted for by the algorithm. Perpendicular areas and those sloped inward (half sphere, cone, studs, etc) should all be safe.
Descriptions of pics:
  1. Standard MillFace operation without adjustments - view 1
  2. Standard MillFace operation without adjustments - view 2 - model hidden
  3. NEW, 'ExcludeRaisedAreas' feature enabled - view 1
  4. NEW, 'ExcludeRaisedAreas' feature enabled - view 2 - slot is milled over, stud is excluded
Enjoy this gluten-free delight,
Russ
dubstar-04
Re: [Merged] MillFace: add feature - exclude raised areas PR #2367
Post by dubstar-04 »
Hi Russ,
Opening old models and trying to make facing operations active gives the following segfault:
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathUtils.py", line 64, in new_function
    res = function(*args, **kwargs)
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathOp.py", line 503, in execute
    result = self.opExecute(obj) # pylint: disable=assignment-from-no-return
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathAreaOp.py", line 400, in opExecute
    aOS = self.areaOpShapes(obj) # pylint: disable=assignment-from-no-return
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathMillFace.py", line 126, in areaOpShapes
    if obj.ExcludeRaisedAreas is True:
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'ExcludeRaisedAreas'
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x43f60) [0x7fb3feb92f60]
#1  [0x557547ea5440]
File attached.
Partial version info here: (not sure why this is incomplete)
OS: Ubuntu 19.04 (ubuntu:GNOME/ubuntu)
Version: 0.19.
Python version: 3.7.3
Qt version: 5.12.2
DizzyBlank2-CAM.fcstd
(237.88 KiB) Downloaded 36 times
dubstar-04 wrote: Wed Aug 14, 2019 6:16 am Opening old models and trying to make facing operations active gives the following segfault:
They were built with which version? If it is 0.19 I would not consider this as really serious., because rebuilding them shows no issues.
But there is something else which should be fixed by reattaching Sketch003: You have a cyclic dependency in your model.
Snip macro screenshot-608492.png (17.47 KiB) Viewed 894 times
dubstar-04
chrisb wrote: Wed Aug 14, 2019 6:32 am
How do you reply to all these posts so quickly? Amazing service!!
This is my testing model. The path objects have been built recently (2 weeks ago?) using daily versions of 0.19.
I have reattached that sketch, new file attached.
FreeCAD no longer segfaults, but it would be nice if the error was handled a little better.
Thanks,
Dan
DizzyBlank3-CAM.fcstd
(239.08 KiB) Downloaded 19 times
dubstar-04 wrote: Wed Aug 14, 2019 6:52 am How do you reply to all these posts so quickly? Amazing service!!
This is a special kind of lazyness: I actually should do something else, but sometimes I prefer to work through the forum here.
dubstar-04
chrisb wrote: Wed Aug 14, 2019 11:38 am
Well keep it up. Having people like you that provide such great support is what makes FreeCAD so special. :D
Russ4262
Post by Russ4262 »
Afternoon, Sir,
As ChrisB has mentioned, this error is not a high priority and has an existing solution.
dubstar-04 wrote: Wed Aug 14, 2019 6:16 am Hi Russ,
Opening old models and trying to make facing operations active gives the following segfault: ...
This error stems from the method used by devs to add a new property to an existing operation or tool. If the dev simply declares the property upon initialization, the property is only added upon initial creation of the operation - meaning, no backwards compatibility with operations/jobs created with previous versions of FreeCAD. The second method involves the inclusion of a simple test case to determine if the property exists when the operation is recomputed or recovered (when a document is reopened), with the occasional line or two of additional code to ensure the property existence test is run each time the document is opened/recomputed.
I suspect the first method mentioned is the source of the error here. You will simply have to delete and re-create the operation within the new FreeCAD version so the new, additional properties are included with the operation.
I am one of the devs responsible for using the first method at times within my contributions to the PathWB - it is quick and easy. You may run into this error using pre_0.19 when opening files with jobs and operations created in previous versions -- that have had additional properties added as dependencies of new features, or improvements of existing features.
I think checking each operation/job/tool script in PathWB having received property modifications in pre_0.19 would be a great task to add to the pre-release polishing for PathWB before the official release is made, to allow existing files containing jobs and operations to be opened and compatible with what will be the new release - without having to re-create jobs or operations.
Thanks for the feedback.
Russell
dubstar-04
Russ4262 wrote: Thu Aug 15, 2019 1:29 am
Hi Russ,
Thanks for the reply. ^^ This certainly would be nice if someone had time.
Dan
