Bug in profile operations
IMback!
Post by IMback! »
A bug causes profiling operations to sometimes output wrong profile
testPart.FCStd
(21.08 KiB) Downloaded 73 times
Re: Bug in profile operations
Confirmed here, default tolerance and curve accuracy is 0.01mm. Please add your FreeCAD infos as well. You should do that with every issue found.
OS: macOS High Sierra (10.13)
Version: 0.19.17512 (Git)
Hash: 7b315d3a15f6c0a3e796b2bf000cb791092de079
Python version: 3.7.3
Qt version: 5.9.7
Locale: English/Germany (en_DE)
herbk
Post by herbk »
I have the same behavior at
OS: openSUSE Leap 15.1 (KDE//usr/share/xsessions/plasma5)
Version: 0.19.17512 (Git) AppImage
Qt version: 5.9.7
and
Version: 0.18.Unknown
Python version: 3.6.5
Qt version: 5.9.7
Coin version: 3.1.3
Gruß Herbert
herbk
Post by herbk »
If i make a part like yours (different size) with Part WB i get a regular path.
testPart_herbk.FCStd
(27.13 KiB) Downloaded 69 times
Gruß Herbert
I recreated the PartDesign model from scratch, just to make sure I didn't miss anything. Besides the sketch, where I used the same dimesnions as IMback, I used only default values for padding, job, tool, and contour.
The path in this model shows two defects:
Bildschirmfoto 2019-08-13 um 00.34.08.png (14.38 KiB) Viewed 2315 times
testPart_cb.FCStd
(17.04 KiB) Downloaded 78 times
evaine23
Post by evaine23 »
Has anyone found a way to fix the error in the path profile operation? I'm running into the same problem. I'm pretty new to CAD work so it might be something i'm doing wrong. If I create a sketch similar to the one above using circles rather than ellipses for the rounded ends, my path appears correct. I've tried a few different versions of FreeCAD with the same results. I have run into this problem with a more complex part that I don't think i could recreate using the part workbench.
OS: Debian GNU/Linux bullseye/sid (X-Cinnamon/cinnamon)
Version: 0.19.18213 (Git) AppImage
Hash: 22babc09954ac6fda9135ee71d68550921659b1c
Qt version: 5.12.1
IMback!
Post by IMback! »
I have ben trying to figure out why this happens, but have not made mutch headway.
herbk
Post by herbk »
evaine23 wrote: Sun Sep 15, 2019 6:10 pm I have run into this problem with a more complex part that I don't think i could recreate using the part workbench.
I use Part together with Sketcher only and can create each part i need till now. Maybe sometimes a few clicks more... but less probs ;)
Gruß Herbert
There is no advantage when doing it in Part WB, the same deformed path is generated.
Version: 0.19.18095 (Git)
Hash: 27cb54009b57c1938f7ff97026c8b35c1688233f
Qt version: 5.12.1
deformedPathfromPartWB_cb.FCStd
(14.69 KiB) Downloaded 62 times
herbk
Post by herbk »
chrisb wrote: Wed Sep 18, 2019 5:40 pm There is no advantage when doing it in Part WB, the same deformed path is generated.
You are right... :oops:
Here the error occures only if i use the Sketcher tool "Create a Conic", if i use "Arc of Parabola" i get a valid path for the part.
But: If i cuse Create a Conic, i got the error message
<Part> PartFeature.cpp(191): 16Standard_Failure Index out of bound: deformedPathfromPartWB_cb#Sketch002.Vertex19
I don't understand why it starts with <Part>, i work in Sketcher...
deformedPathfromPartWB_cb_herbk.FCStd
(43.29 KiB) Downloaded 67 times
Gruß Herbert
