3d face go though object
hi,
my problem is that if i import a step-file (from grabcad) and want to make a cnc-program the path goes though the object lke in the picture.
i hope it is visible, there are green lines under the object. at the top the lines stop like the heigh gut under the top they go again.
why ?
what am i doing wrong ?
why ?
- fehlerfraes.png (161.98 KiB) Viewed 1566 times
- dubstar-04
Re: 3d face go though object
Please could you post your FreeCAD version?
See here: https://forum.freecadweb.org/viewtopic.php?f=3&t=5236
There has been a significant amount of work done on 3D toolpaths recently.
Cheers,
Dan
Cheers,
Dan
sorry
OS: Windows 7
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
OS: Windows 7
Qt version: 5.6.2
- dubstar-04
Please can you post a link to the grabcad model or share your FreeCAD model?
I will try it on the development build.
Thanks,
Dan
Thanks,
Dan
i cann not attach because the file ist too big
but the download link (if you are registrated, if not gve me your email-adress)
https://grabcad.com/library/apc-propeller-14-x-8-1
- dubstar-04
The 3D Pocket OP fails for this use case, However the 3D Surface operation generates tools paths:wbeppler wrote: ↑Wed Aug 14, 2019 5:20 pm i cann not attach because the file ist too big
If the path could be contained to an area or surface more easily this would be ideal.
Thanks,
Dan
OS: Ubuntu 19.04 (ubuntu:GNOME/ubuntu)
Version: 0.19.
Python version: 3.7.3
Qt version: 5.12.2
sorry, that is my probelm
i can not find
"3D Surface operation"
where is it, can you show me the icon i have to klick to ?
sorry i am stupid. i tried all in the part-menu but in my version the texts are different
(whitch file did you import ? step igs oder stl ?)
in the first picture of my screenshot you can see the symbols i have . which one ?
thanks a lot
i can not find
thanks a lot
- dubstar-04
You will need to install OpenCamLIb (OCL)
https://www.freecadweb.org/wiki/OpenCamLib
It should appear under the same menu as the 3D Pocket Operation.
Thanks,
Dan
Thanks,
Dan
hello,
now i updatet on my ubuntu 18.x to freecad daily 0.19
i tested with step and iges
allways the same, the path goes through the object
i attach the tool-list, pleas tell me whitch one i should use
thanks
thanks
- werkzeuge.png (11.32 KiB) Viewed 1470 times
sorry dan,
i have seen that post in the moment i did send my one
i will try to install this package
thanks
thanks
