Simple engraving question
falviani
Re: Simple engraving question
Postby falviani » Tue Aug 20, 2019 3:03 pm
Sorry about that :( The delay in responding is solely due to life happening here...
I created another file in an attempt to just engrave a traced image. Attached is the file and the error log that resulted from trying to execute the engrave operation. I am sadly coming to the conclusion that FreeCAD is not designed to do what I want to do :(
ImageTracing_v1.FCStd
(25.45 KiB) Downloaded 7 times
ErrLog_08-20-19.txt
(1.53 KiB) Downloaded 7 times
sliptonic
Postby sliptonic » Tue Aug 20, 2019 4:12 pm
Are you trying to do this?
I deleted and recreated the job so the tool and depths might need to be adjusted.
(16.59 KiB) Downloaded 13 times
falviani
Postby falviani » Tue Aug 20, 2019 5:43 pm
Yes, I was. And I found a way to do it using the fromshape operation properly (use the linked sketch when setting up the job). I just tried a first version of this on my tiny router and it worked (file is attached). I think I just need to do several more projects to get the workflow solid. I thank you all for your help! :D
ImageTracing_v2.FCStd
(318.25 KiB) Downloaded 5 times
falviani
Postby falviani » Wed Aug 21, 2019 8:07 pm
Hello again,
I tried another file to get the process of setting up an engraving job using imported images down, and I'm clearly missing a step. This combines an imported image and a couple of stringshapes that have been converted to sketches, and then the sketches were combined. I then used the 'fromshape' operation, and used the results of that as the model for the job. Looking at the gcode for the engrave operation shows it's empty, but examining the gcode for the pathshape shows the sort of gcode I'd expect. What am I doing wrong (I apologize for not writing down *every* detailed step I took in creating the previous file - maybe then I wouldn't be asking this) And how is the PathShape expected to be used in an operation?
Thanks in advance again. :oops:
ImageTracing_v3.FCStd
(188.8 KiB) Downloaded 6 times
