Dogbone dressup not on one corner
Re: Dogbone dressup not on one corner
Postby chrisb » Tue Aug 27, 2019 5:30 am
Retested with the version below and it still works:
- load file PathTest_13c.FCStd
- mark DogboneDressup for recompute
- recompute
and there it is.
Perhaps it is a precision issue, I have set tolerance and accuracy both to 0.01mm.
OS: macOS High Sierra (10.13)
Version: 0.19.17893 (Git)
Hash: 7a85b762652977605e6cf5c31c20a2beb308e5aa
Python version: 3.7.3
Qt version: 5.9.7
Locale: English/Germany (en_DE)
Halfa
Postby Halfa » Tue Aug 27, 2019 6:52 am
- recompute
and there it is.
Thanks chrisb.
I'll play around a bit more and see if I can track down what is causing my problem
Arthur
schnebeck
Postby schnebeck » Fri Aug 30, 2019 10:26 am
Use "Adaptive" - it works the way you want. ;)
HTH
Thorsten
PathTest_13c-Adaptive.FCStd
(182.52 KiB) Downloaded 11 times
Halfa
Postby Halfa » Mon Sep 02, 2019 1:17 am
HTH
Thorsten
Thanks for replying.
I haven't got as far as looking at Adaptive yet. I'm still working my way through the dressups.
The only problem I can see with your suggestion is that the tool will spend most of its time rubbing already machined surfaces whether I do a Contour before or after Adaptive.
The Dogbone looks more efficient and appears to work almost always after a recompute.
I have had problems with FreeCAD crashing when deleting a Dogbone and it doesn't recover.
Also I have experienced different things occurring a couple of times, but they aren't repeatable enough to document. eg twice simply double clicking the Dogbone dressup without doing a recompute has fixed the Dogbone.
I need to spend more time investigating because I think the dressups will be very useful.
Halfa
mlampert
Postby mlampert » Mon Sep 02, 2019 2:57 am
Sorry for the late reply, I created a PocketShape with an extension and I think the result is quite nice. Added a Profile to make sure the square gets milled correctly though. Note that if you want to make absolute sure you can make the extension wider. By default it extends by half a tool diameter.
Apologies for the perspective view - I don't know where it came from and have trouble turning it off again.
PathTest_13b.FCStd
(52.46 KiB) Downloaded 12 times
schnebeck
Postby schnebeck » Mon Sep 02, 2019 6:03 am
Interesting - extension option was under my radar so far. *top*
