Tag dressup problems - disappearing when saved, no selection indicator when moving.
Halfa
Post by Halfa »
I select a Tag in the list, the ball indicator changes colour and size, and Edit becomes active.
Click Edit and the cursor is a normal pointer until it is moved near or over the model when it becomes a red circle with a slash through it.
Click where I want the Tag to move to and the orange Tag ball indicator moves to the selected position.
Click Apply and the path partially shows the new Tag position, and partially removes the Tag from the old position.
Clicking OK makes the path correct.
In a video on the Tag dressup there was a small circle to indicate where the cursor for the Tag was.
I am getting a small red circle with a slash through it. (A "not allowed" type sign).
However it does work.
A second issue is with Tag dimensions disappearing when the file is saved and re-opened.
Save the document.
Close the document.
Re-open the document.
Open the Tag dressup and the Width and Height of the Tags are now zero although the 3D view still shows Tags in the path.
A third issue is that occasionally I can select a Tag in the 3D view but mostly I can't, and I haven't been able to track down how and when I can select them. I will keep looking into this.
I have attached the file and the path shows where the Tags are, but the dimensions have been lost. I have to re-do the Tags every time I open the file.
OS: Windows 10 (10.0)
Version: 0.19.17877 (Git)
Hash: 1e19ef5be4735f4200eaf99ce9e487d2be6f4151
Python version: 3.6.8
Qt version: 5.12.1
PathTest_9b.FCStd
(29.03 KiB) Downloaded 36 times
Halfa
Re: Tag dressup problems - disappearing when saved, no selection indicator when moving.
Post by Halfa »
I have a little bit more information on the holding tags that go missing when a file is saved and re-opened.
I created a simple model with a contour around the outside.
I applied the tag dressup with my default of four tags.
The default tag dimensions are 5mm long and 2.25mm high.
Tag 1.png (12.06 KiB) Viewed 834 times
Save the document.
Close the document.
The Data panel for the tag dressup shows the correct values for height and width.
Tag 2.png (14.95 KiB) Viewed 834 times
If I double click on the tag dressup, the width and height are 0.
Tag 3.png (15.77 KiB) Viewed 834 times
Of course, if I click Apply and OK, the zeros are copied to the data panel.
I have tried this on both a Windows 10 system and Linux Mint, and several different versions of FreeCAD over the last three weeks, and all have the same problem.
Can anyone please confirm this is a bug, or that am I doing something wrong?
PathTest_9a.FCStd
(28.75 KiB) Downloaded 34 times
Version: 0.19.18024 (Git)
Hash: 9cc8f6eb666b0a0ae2dc256f7bc0beb8c987710c
Qt version: 5.12.1
OS: Linux Mint 19.2 (MATE/mate)
Version: 0.19.18009 (Git) AppImage
Hash: 0641ca0d1e020d18f23d2adb49959195266f04f7
Python version: 3.7.3
Qt version: 5.12.1
