toolmanager bombed out , all tools gone.
freman
Re: toolmanager bombed out , all tools gone.
Postby freman » Mon Oct 07, 2019 7:45 pm
thanks, I realise that. I've been building FreeCAD and thunder's asm3 from source for about a year now. That involved building a number of other libs from source too, and I've seen the build on Unix guide.
I have a specific problem since trying to switch from qt4 to qt5. Sometimes it's a bit of guessing game to find out exactly what package is missing, or whether there is a flaw in the build scripts or a distro specific quirk. If you can see anything more specific , that would be very helpful.
freman
Postby freman » Mon Oct 07, 2019 8:14 pm
mlampert:
As for your tools, the default tool library is stored in your FC settings. You can look at "Tools" -> "Edit Parameters ..." -> "Preferences" -> "Mod" -> "Path". If there is a "ToolLibrary-Main" entry, then the value is your json formatted tool library. If there is nothing there then it's really gone, unless you exported it at some point.
"ToolLibrary-Main" entry shows this:
[{"Tools": {}, "Version": 1, "TableName": "Tool Table-1"}]
Is that what you meant ?
freman
Postby freman » Mon Oct 07, 2019 8:26 pm
this getting a bit crazy. I don't understand what is going on here.
I did
 git pull
 git checkout master
 git checkout src
then switched to an earlier build to try to get around the problem.
I removed the contents of the build dir with rm -rf , ran cmake ../freecad-source to get a previous build using py2/qt4 , this is my new FC info:
OS: Linux (LXDE/LXDE)
Version: 0.19.18058 (Git)
Build type: Unknown
Branch: (HEAD detached at 871de20de)
Hash: 871de20deae2cd5909ab69c7ca1348a8994768f9
Python version: 2.7.16
I still have exactly the same issue , either from Menu | Path | Toolmanager or via the comboview Job Editor | Tools tab | "Add" button.
  File "/~/freecad-master-py3-build/Mod/Path/PathScripts/PathJobGui.py", line 857, in toolControllerAdd
    PathToolLibraryManager.CommandToolLibraryEdit().edit(self.obj, self.updateToolController)
  File "/~/freecad-master-py3-build/Mod/Path/PathScripts/PathToolLibraryManager.py", line 859, in edit
    editor = EditorPanel(job, cb)
  File "/~/freecad-master-py3-build/Mod/Path/PathScripts/PathToolLibraryManager.py", line 521, in __init__
    self.TLM = ToolLibraryManager()
  File "/~/freecad-master-py3-build/Mod/Path/PathScripts/PathToolLibraryManager.py", line 162, in __init__
    self.loadToolTables()
  File "/~/freecad-master-py3-build/Mod/Path/PathScripts/PathToolLibraryManager.py", line 301, in loadToolTables
    tt = self.tooltableFromAttrs(table)
  File "/~/freecad-master-py3-build/Mod/Path/PathScripts/PathToolLibraryManager.py", line 260, in tooltableFromAttrs
    tt.Name = stringattrs.get('TableName')
TypeError: cannot return std::string from Unicode object
Per previous details, it seems that a tooltable is still referenced in the parameters. Maybe it has been written with some unicode value included which is causing the error.
mlampert
Postby mlampert » Mon Oct 07, 2019 8:42 pm
From your output above your tool table seems to be empty and the TableName is a regular string. I would probably suggest removing your configuration files, I have the feeling that something else in the config file got out of whack and it's spilling into the tool table.
freman
Postby freman » Mon Oct 07, 2019 8:52 pm
I've found what looks like an anomalous gap in user.cfg, 30 apparently blank lines. Is this relevant?
          <FCParamGroup Name="FemWorkbench"/>
          <FCParamGroup Name="NoneWorkbench"/>
          <FCParamGroup Name="gearWorkbench"/></FCParamGroup>
        <FCParamGroup Name="System">
          <FCParamGroup Name="PathWorkbench"/>
        </FCParamGroup>
      </FCParamGroup>
      <FCParamGroup Name="NavigationIndicator">
        <FCBool Name="Compact" Value="0"/>
        <FCBool Name="Tooltip" Value="1"/>
      </FCParamGroup>
    </FCParamGroup>
    <FCParamGroup Name="Plugins">
      <FCParamGroup Name="addonsRepository">
        <FCBool Name="readWarning" Value="1"/>
      </FCParamGroup>
    </FCParamGroup>
  </FCParamGroup>
mlampert
Postby mlampert » Mon Oct 07, 2019 8:55 pm
The blank lines I don't know, but the additional end tag doesn't look like valid XML to me. Not an expert though.
freman
Postby freman » Mon Oct 07, 2019 9:18 pm
Thanks, that does look broken.
I also removed FCgear from the tree and rebuilt. I thought I would have got a clean tree from git checkout master but it seems not.
This gives me a slightly different error in the same circumstances.
Path workbench activated
Running the Python command 'Path_ToolLibraryEdit' failed:
  File "/~/freecad-master-py3-build/Mod/Path/PathScripts/PathToolLibraryManager.py", line 877, in Activated
    self.edit()
  File "/~/freecad-master-py3-build/Mod/Path/PathScripts/PathToolLibraryManager.py", line 293, in loadToolTables
    prefsData = json.loads(self.prefs.GetString(self.PreferenceMainLibraryJSON, ""))
  File "/usr/lib64/python2.7/json/__init__.py", line 339, in loads
    return _default_decoder.decode(s)
  File "/usr/lib64/python2.7/json/decoder.py", line 364, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/lib64/python2.7/json/decoder.py", line 382, in raw_decode
    raise ValueError("No JSON object could be decoded")
freman
Postby freman » Mon Oct 07, 2019 9:33 pm
still seeing odd gaps coming back after removing cfg files. :(
git reset --hard
Is that the right command to get me properly synced with the official tree ?
DeepSOIC
Postby DeepSOIC » Mon Oct 07, 2019 10:23 pm
btw, people are still using py2-qt4 because of 3d view issues of py3-qt5.
See also Py2ectomy thread.
mlampert
Postby mlampert » Mon Oct 07, 2019 10:40 pm
That's hard to say, depends on your branch and when you pulled/fetched the last time.
What I do is fetch the latest changes to freecad, then swtich to a new branch based on freecad/master. I build out of source so I delete the build directory and create a new build. I don't know enough about cmake and ccache to know when to do what, so I just start from a clean slate each time.
