How is Clearance Height Calculated & How Does One Change It?
ivxcvi
Postby ivxcvi » Wed Oct 16, 2019 7:01 am
The title basically says everything. I am trying to use FreeCAD to output GCode for a Maslow CNC--which has minimal clearance & Safe Height. Right now Clearance is calculated at over 21mm. I would like to have that down to 6mm. I'm just not sure what I need to adjust to do that. Documentation doesn't appear clear on that issue.
Much appreciated,
Re: How is Clearance Height Calculated & How Does One Change It?
Postby chrisb » Wed Oct 16, 2019 8:11 am
Have a look at Job->Setup->DefaultValues.
RatonLaveur
Postby RatonLaveur » Wed Oct 16, 2019 2:42 pm
Be careful that in FreeCAD Clearance Height and Safe Height are inverted with regards to conventional machinimg nomenclature. So double check the heights and the travels.
Postby Kunda1 » Mon Oct 28, 2019 6:39 pm
Welcome, please keep us updated on your progress with FreeCAD and MaslowCNC. Thanks!
geant
Postby geant » Thu Nov 14, 2019 12:58 am
Thanks for saying that "out loud"; this has been bugging me for years!
RatonLaveur
Postby RatonLaveur » Thu Nov 14, 2019 11:33 am
Yep, Safe height is supposed to be the height for which any lateral movement in the machine will clear both part, features and fixtures.
Clearance height is a reduced retraction used to clear features on a single work-piece or work-piece area (typically, move from one pocket to another).
An overly cautious machinist or hobbyist will probably accept Safe height as the only default parameter. A machinist more interested in optimizing cycle times (or who likes to live dangerously) will happily rapid around at clearance height.
In FreeCAD: both are inverted. Hence why Clearance Height is by default higher than Safe Height. Since the automatic generation of travels was coded this way, I would not mess with their relative positions to "try" to emulate correct nomenclature.
ivxcvi
Postby ivxcvi » Sun Dec 01, 2019 3:23 am
I found that my issue was that I was padding my designs in a positive direction, causing the clearance height to be well beyond the Maslow's Z-height threshold. Padding designs in reverse & sticking to default values solved my issue.
Also of note for anyone getting started with FreeCAD+MakerMade/Maslow CNC, don't forget to set your feedrates & rapid mm/s (42 for H & V Feed, 100 for H & V Rapid). After I figured out the Z-height issue, I was wondering why my Maslow stalled before the first cut. Big thanks to Walt_Moorhouse over on the Maslow CNC forums for the FreeCAD guide which has helped me overcome these issues.
Thanks!
Postby chrisb » Sun Dec 01, 2019 7:40 am
I see that there is a FreeCAD world outside of this forum. As you are active there, would you mind directing the author here or submit the following:
May I kindly suggest some corrections and improvements?
Issues:
- The sketch is created outside of a body adding unnecessary work
- The sketch is not constrained (not really a problem only an issue)
- In Step 6 you create already a body before even having a solid
I suggest:
Step 2: Open PartDesign workbench and create a new sketch. (This creates an enclosing body.)
Step 3: choose XY plane as before, but it will look different
Step 4: I would recommend to add dimensions for, lets say an 8mm bit
Step 6: move the images to the job creation step.
ivxcvi
Postby ivxcvi » Sun Dec 01, 2019 8:50 am
Thanks for the input. I've submitted the suggestions with a link back to your post. Much appreciated!
