Omitting one or more sides when contouring/profiling
tomi_wunder
Postby tomi_wunder » Sun Oct 27, 2019 2:08 pm
For a little furniture project I've designed a simple corner joint (e.g. for making box drawers etc.)
and I'd like to create a simple toolpath to produce this joint on my CNC router. Profiling the whole part (as designed) from all four sides (front, left, back, right) is easy to do. However I can't seem to find a way how to generate a path for only machining the "finned" side (as selected in the screenshot), but not the left, right and rear (straight) sides.
I would be really happy if you could help me out. I've searched this forum high and low, but maybe I'm just using the wrong terms...
Thanks in advance!
schnebeck
Re: Omitting one or more sides when contouring/profiling
Postby schnebeck » Sun Oct 27, 2019 8:07 pm
It would be easier to help you if you can attach a FreeCAD file and tell us something about your FreeCAD version ;-)
See here:https://forum.freecadweb.org/viewtopic.php?f=3&t=2264 Point #4 & #6
Bye
Thorsten
herbk
Postby herbk » Sun Oct 27, 2019 8:48 pm
Hi Thorsten,
it's not in this case, ;)
For the same question are 3 or 4 threads at the first page of Path help Forum... :roll: :roll:
Gruß Herbert
tomi_wunder
Postby tomi_wunder » Mon Oct 28, 2019 8:52 am
Sorry, I stupidly forgot to do so. I beg your pardon!
My FreeCAD version is
OS: Debian GNU/Linux 9 (stretch)
Version: 0.18.16131 (Git) AppImage
Branch: (HEAD detached at 0.18.3)
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.7
Qt version: 5.6.2
Locale: C/Default (C)
Attached is the project file. As already pointed out, the normal contouring operation goes all round the work piece. I however need to exclusively machine the "front" side (where the "rounded dovetails", or rather call them fins) are, but not the three straight sides.
(In the project file I'm also using the tag dressup, because, as I coundn't figure out how to keep the path going all round the piece I needed the holding tags for making some samples to find out if the joint would work in general. So please ignore that dressup.)
dovetail1.FCStd
project file
(66.91 KiB) Downloaded 12 times
schnebeck
Postby schnebeck » Mon Oct 28, 2019 1:41 pm
Hi Thorsten,
I know... "Use a base plate, Luke" - but its still interesting if this is FC 0.16 or a later version.
Bye
Thorsten
schnebeck
Postby schnebeck » Mon Oct 28, 2019 2:19 pm
I don't know if we already had this way - maybe its a new solution:
Here I close the loop via a displaced stock and used my beloved adaptive inside ;-)
This only works with adaptive, as this tool works not only with a strict but also with a "somehow" closed edge selection.
HTH
thorsten
Postby chrisb » Mon Oct 28, 2019 2:41 pm
Hey, that's a great solution for this recurring issue. Wish we had non cubic stock :mrgreen: .
schnebeck
Postby schnebeck » Mon Oct 28, 2019 2:46 pm
Hmm, Stock can also be a cylinder or any existing solid, this includes helper plates ;-)
RatonLaveur
Postby RatonLaveur » Mon Oct 28, 2019 8:18 pm
Could this be automated? Seems like the perfect base for a tool to machine only selected areas...
Postby chrisb » Mon Oct 28, 2019 9:53 pm
Just saw it with delight :D , but I didn't succeed in creating a partial path. Would you mind uploading your file for investigation?
