path WB: regression in FC 0.19
uwestoehr
Post by uwestoehr »
The path WB does no longer work properly in FC 0.19. I cannot create even a simple pocket.
To reproduce:
1. open this example file:
Path-test.FCStd
test file
(22.89 KiB) Downloaded 35 times
2. Create a path job (use the proposed default settings)
result: After the final press on OK to get the job created, nothing happens, but I get in the report widget these errors:
PathJobGui.ERROR: 'PySide2.QtWidgets.QDialog' object has no attribute 'widget'
  File "D:\FreeCAD-build\Mod\Path\PathScripts\PathJobGui.py", line 1315, in Create
    obj.ViewObject.Proxy.editObject(obj.Stock)
  File "D:\FreeCAD-build\Mod\Path\PathScripts\PathJobGui.py", line 195, in editObject
    return self.openTaskPanel('Stock')
  File "D:\FreeCAD-build\Mod\Path\PathScripts\PathJobGui.py", line 174, in openTaskPanel
    self.taskPanel = TaskPanel(self.vobj, self.deleteObjectsOnReject())
  File "D:\FreeCAD-build\Mod\Path\PathScripts\PathJobGui.py", line 567, in __init__
    self.template = PathJobDlg.JobTemplateExport(self.obj, self.form.jobBox.widget(1))
AttributeError: 'PySide2.QtWidgets.QDialog' object has no attribute 'widget'
3. retry to setup a path job. Now you it works.
4. Create a path pocket (choose a pocket of your choice)
(This is what I have now:
Path-test-pocket-result.FCStd
result after step 4
(35.58 KiB) Downloaded 32 times
5. Post process the whole job
result:
Running the Python command 'Path_Post' failed:
  File "D:\FreeCAD-build\Mod\Path\PathScripts\PathPost.py", line 390, in Activated
    (fail, rc) = self.exportObjectsWith(finalpostlist, job)
  File "D:\FreeCAD-build\Mod\Path\PathScripts\PathPost.py", line 212, in exportObjectsWith
    gcode = processor.export(objs, filename, postArgs)
  File "D:\FreeCAD-build\Mod\Path\PathScripts\PathPostProcessor.py", line 102, in export
    return self.script.export(obj, filename, args)
  File "D:/FreeCAD-build/Mod/Path/PathScripts//post\centroid_post.py", line 170, in export
    if isinstance(item.Proxy, PathScripts.PathToolController.ToolController):
'_TempObject' object has no attribute 'Proxy'
With FC 0.18.3 I get no problems at all.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18638 (Git)
Hash: d6fc794aca0d5dd8b6e1d5f99360f792dbf73199
Python version: 3.6.8
Qt version: 5.12.1
Re: path WB: regression in FC 0.19
It still works with the version below. Can you try to reset your settings?
OS: macOS High Sierra (10.13)
Version: 0.19.18589 (Git)
Hash: 3500451a040989d00693eab85b2a7c13ce4dad67
Python version: 3.7.3
Qt version: 5.12.5
Locale: English/Germany (en_DE)
uwestoehr
Post by uwestoehr »
chrisb wrote: Tue Oct 29, 2019 10:38 am It still works with the version below. Can you try to reset your settings?
I did so but the problem persists. As you cannot reproduce it with rev 0.19.18589 The issue must have been introduced recently between this revision and rev 0.19.18638.
uwestoehr
Post by uwestoehr »
uwestoehr wrote: Tue Oct 29, 2019 1:16 pm As you cannot reproduce it with rev 0.19.18589 The issue must have been introduced recently between this revision and rev 0.19.18638.
This is not true, because when trying with
OS: Windows 10 (10.0)
Version: 0.19.18234 (Git)
Hash: 3af5d97e9b2a60823815f662aba25422c4bc45bb
Qt version: 5.12.1
only the first error is gone, the second error - when postprocessing the job - is there as well.
I'll now try a Conda build and report back.
mlampert
Post by mlampert »
works for - certainly no help for you though. Given the error you're getting it sounds more like PySide / Qt issue. Maybe our build experts have some insight.
OS: Debian GNU/Linux bullseye/sid (LXQt//usr/share/xsessions/lxqt)
Build type: Debug
Python version: 3.7.5rc1
Qt version: 5.11.3
uwestoehr
Post by uwestoehr »
mlampert wrote: Tue Oct 29, 2019 6:48 pm works for - certainly no help for you though. Given the error you're getting it sounds more like PySide / Qt issue. Maybe our build experts have some insight.
The 0.19.18234 build is one I downloaded from GitHub , the 0.19.18638 build was built by myself. Both used the LibPack available in the 0.19 release on GitHub.
I cannot test a Conda build because all downloads from GitHub are today super slow and sooner or later terminated. (Seems amazonaws.com has problems.)
However, the error
sounds strange. Note also the wrong double slashes in the path:
____________________________________^
mlampert
Post by mlampert »
uwestoehr wrote: Tue Oct 29, 2019 7:15 pm
Double slashes are typically not an issue and it seems the python interpreter can find your file - so even the backslash seems to be OK. I have no idea what a _TempObject is and what it's doing there though.
I can retry when the new MacOS version is out.
uwestoehr
Post by uwestoehr »
uwestoehr wrote: Tue Oct 29, 2019 7:15 pm I cannot test a Conda build because all downloads from GitHub are today super slow and sooner or later terminated. (Seems amazonaws.com has problems.)
I got it now:
Version: 0.19.18640 (Git)
Hash: 2251f53eb5af097cbb4b879af89575132660e541
Qt version: 5.12.1
I get the same error. But I see now that it is related to the output processor. I use the default "centroid". When using e.g. "grbl", I get no error and a correct output.
I investigated a bit and I encountered this:
centroid:
  File "C:\FreeCAD\FreeCAD_0.19.18640_x64_Conda_Py3QT5-WinVS2015\Mod\Path\PathScripts\PathPost.py", line 390, in Activated
  File "C:\FreeCAD\FreeCAD_0.19.18640_x64_Conda_Py3QT5-WinVS2015\Mod\Path\PathScripts\PathPost.py", line 212, in exportObjectsWith
  File "C:\FreeCAD\FreeCAD_0.19.18640_x64_Conda_Py3QT5-WinVS2015\Mod\Path\PathScripts\PathPostProcessor.py", line 102, in export
  File "C:/FreeCAD/FreeCAD_0.19.18640_x64_Conda_Py3QT5-WinVS2015/Mod/Path/PathScripts//post\centroid_post.py", line 170, in export
jtech:
  File "C:/FreeCAD/FreeCAD_0.19.18640_x64_Conda_Py3QT5-WinVS2015/Mod/Path/PathScripts//post\jtech_post.py", line 222, in export
    gfile = pythonopen(filename, "wb")
name 'pythonopen' is not defined
philips:
  File "C:/FreeCAD/FreeCAD_0.19.18640_x64_Conda_Py3QT5-WinVS2015/Mod/Path/PathScripts//post\philips_post.py", line 389, in export
    if c.Parameters >= 1:
'>=' not supported between instances of 'dict' and 'int'
all other postprocessors work.
I will wait for the new version and check (at least the philips post processor).
