visual feedback for multiple edge selection not working.
freman
Postby freman » Fri Nov 15, 2019 8:12 pm
I've just updated to qt5 build of master from my old qt4 build that was a couple of months old. One of the first things I noticed is that multiple edge selection is not correctly shown in the 3D view.
For example with 'profile based on edges' tool or engraving tool, I am used to holding down cntl key and clicking on several edges to select them. Usually this shows them all in green as the group increases, with a hover colour of yellow. Now I only see the first one indicated in green.
They have been selected as I intended as I can see from the base geometry of the path tool, but visual feedback while selecting seems missing.
Selection in Sketcher seems normal , so I'm concluding this is Path issue.
Is this a known issue?
OS: Fedora 31 (Thirty One) (LXDE/LXDE)
Version: 0.19.18504 (Git)
Branch: (HEAD detached at origin/master)
Hash: f66023a646db4b2502bb3637897443b3525ca3c7
Python version: 3.7.5
Qt version: 5.12.5
mlampert
Re: visual feedback for multiple edge selection not working.
Postby mlampert » Fri Nov 15, 2019 8:28 pm
Just tried and it works for me. I tried pre-selection and task-panel selection.
OS: Debian GNU/Linux bullseye/sid (LXQt//usr/share/xsessions/lxqt)
Version: 0.19.18733 (Git)
Build type: Debug
Hash: 2637280c1d2cb48e7cd946fa9f2484467edd8b0c
Qt version: 5.12.5
freman
Postby freman » Fri Nov 15, 2019 8:43 pm
thanks, what are you meaning by task-panel selection?
herbk
Postby herbk » Fri Nov 15, 2019 8:47 pm
Here it works to
OS: openSUSE Leap 15.1 (KDE//usr/share/xsessions/plasma5)
Version: 0.19.18694 (Git) AppImage
Hash: c3ba04183e016e15410d84bae4d00556d22c7da5
Python version: 3.7.3
Qt version: 5.12.5
Gruß Herbert
mlampert
Postby mlampert » Fri Nov 15, 2019 8:57 pm
I wasn't quite sure how to put that - I meant selecting edges while the ProfileEdge task panel is open.
freman
Postby freman » Fri Nov 15, 2019 9:21 pm
OK, that seems like what I was referring to by " base geometry of the path tool " . The selection mechanism works once I hit the "Add" button, so I know the edges were selected as I intended. It's just that I only see the first edge selected in the 3D view as indicated by a colour change.
Since all three of us are using qt 5.12.5 it seems a little odd we are apparently seeing different results. I was getting normal selection indication in the 3Dview under qt4, so this is all a bit odd.
mlampert
Postby mlampert » Fri Nov 15, 2019 9:38 pm
I noticed that too - even weirder that it works in the sketcher. On top, Path doesn't actually interfere with the 3d view - unless you select a base geometry in which case it sets the selection in the 3d view, which doesn't seem the case for you.
The only theory I can come up with is that maybe your camera position hides the selection. Can you post your file and maybe note which edges you select in which order?
freman
Postby freman » Fri Nov 15, 2019 10:05 pm
sure, I knocked up a trivial demo file of a block.
Take for example TOP view in 3D.
Once I hide Body and make Model-body visible in the combo-view, I see the selection problem. Select say, left edge, then hover top edge ( yellow ) , click top edge ( stays yellow ) take mouse away , goes black as an unselected edge is.
Contrariwise flip the visibilities and work on Body and the second and subsequent edges go green when selected.
Maybe I have false recollections of how qt4 was working or have an incorrect expectation. Maybe this will be a more concrete example to compare results.
thx.
deburr-box.FCStd
(17.39 KiB) Downloaded 8 times
mlampert
Postby mlampert » Mon Nov 18, 2019 1:02 am
Finally remembered to look at your file, seems to be fine for my system:
All I did was edit the Deburr op and remove all existing entries from "Base Geometry" before the recording. Then I'm pressing the left Ctrl key after selection of the first edge while selecting the remaining three edges.
Version: 0.19.18754 (Git)
Build type: Debug
Hash: a5019828cf263ccdec3b6885f845b1ab1c35ac11
Qt version: 5.12.5
Locale: C/Default (C)
freman
Postby freman » Mon Nov 18, 2019 6:15 am
thanks. This is strange. I don't seem to be able to get the problem on this file any more. There must be some other factor involved which I'm missing.
However, if it go back to the real part where I originally had the problem it's still there.
New file attached.
If this opens in the same state as I saved it, it should be in PathWB and have Model-body selected in the combo-view and Top in the 3dView, with the part at 45 degrees.
If I try to selected any two edges with the mouse in the 3dView , only first one gets highlight in green. For the sake of a concrete example, try selecting the inner and outer edges of the chamfer on one of the holes.
Ah, I think I've got it. Going back to the rectangular block. I select model-body in combo view: this selects it in 3dView. Now, if I click the face in 3DView, it selects in green ( only the face, expected ). Now if I select one edge with mouse it gets selected and the face is deselected ( expected ). At this point I am unable to select a second edge using control key and mouse.
In fact , as initially reported, it is selected since if I apply a path the group of edges is used, and I can see in python console Gui.Selection.addSelection called on the relevent edges.
It is just visual indication of multiple selection which is not showing.
At this point I have both files ( and only these files ) open in FC. I flipped to the rectangular block and cleared the python console. Here is the console output of a series of operations which produces the error condition.
Python 3.7.5 (default, Oct 17 2019, 12:16:48)
[GCC 9.2.1 20190827 (Red Hat 9.2.1-1)] on linux
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> # Gui.Selection.clearSelection()
>>> # Gui.Selection.addSelection('deburr_box','Deburr')
>>> # Gui.Selection.addSelection('deburr_box','Clone')
>>> # Gui.Selection.addSelection('deburr_box','Clone','Edge7',-30,9.18058,0)
>>> # Gui.Selection.addSelection('deburr_box','Clone','Edge10',-21.0167,30,0)
selection-problem-complex.FCStd
(272.55 KiB) Downloaded 6 times
