Tools, old Tool, new ToolBit and other fun stuff
Re: Tools, old Tool, new ToolBit and other fun stuff
Postby chrisb » Fri Jan 03, 2020 12:43 am
Walter, looking at your last screenshot: you can clear the Python console with the right mouse menu.
mlampert
Postby mlampert » Fri Jan 03, 2020 12:46 am
chrisb wrote:
Fri Jan 03, 2020 12:41 am
Do these additional icons depend on opencamlib?
No they don't, and neither does the ToolBit code - the only thing that should depend on OCL is the Surface op.
Postby chrisb » Fri Jan 03, 2020 12:46 am
You can try adding EnableExperimentalFeatures as mentioned above. You should, of course, backup your user.cfg.
roerich_64
Postby roerich_64 » Fri Jan 03, 2020 12:48 am
@ChrisB,
opencamlib are the library for 3D-Surface or not... ?!?
mlampert
Postby mlampert » Fri Jan 03, 2020 12:50 am
It looks like you got everything enabled but it still isn't, very disturbing.
Walter, could you post your user.cfg and system.cfg please?
roerich_64
Postby roerich_64 » Fri Jan 03, 2020 12:56 am
i gave them an extension *.txt to post them here:
user.txt
(45.59 KiB) Downloaded 9 times
system.txt
(922 Bytes) Downloaded 6 times
Postby chrisb » Fri Jan 03, 2020 1:00 am
You have a blank added to "EnableExperimentalFeatures".
mlampert
Postby mlampert » Fri Jan 03, 2020 1:05 am
Nobody beats chrisb 8-)
roerich_64
Postby roerich_64 » Fri Jan 03, 2020 1:06 am
:shock: :shock: I think there is the Boolean at thrue:
mlampert
Postby mlampert » Fri Jan 03, 2020 1:08 am
It's the space at the end of "EnableExperimentalFeatures ", the space before the closing quotation mark which causes the problem.
