Tools, old Tool, new ToolBit and other fun stuff
roerich_64
Re: Tools, old Tool, new ToolBit and other fun stuff
Postby roerich_64 » Fri Jan 03, 2020 1:16 am
You are the greatest!!!
Now i can sleep tonight :lol: :lol:
mlampert
Postby mlampert » Fri Jan 03, 2020 1:20 am
Great! If you can, maybe I can too :D
Postby chrisb » Fri Jan 03, 2020 8:36 am
It was my last post last night. Glad to see it worked.
memfis
Postby memfis » Fri Jan 03, 2020 9:29 am
that's how it is, only the tools are not added through the add button and the error is not displayed.
Снимок экрана от 2020-01-03 12-27-01.png (189.75 KiB) Viewed 196 times
memfis
Postby memfis » Fri Jan 03, 2020 9:33 am
and a bug about the installation number it shows not only on my, new, but also the standard one, from the program delivery.
/Bit$ cat FR_6.35.fctb
"version": 2,
"name": "Радиусная d12.75 R6.35",
"shape": "radius_vogn.FCStd",
"attribute": {},
"parameter": {
"ds": "6.35 mm",
"L": "50.000 mm",
"Diameter": "12.75 mm",
"hR": "5.35 mm",
"Rv": "7,000 mm",
"H": "10.02 mm"
cat Library/endmills.fctl
"tools": [
"nr": 1,
"path": "t1.fctb"
"nr": 2,
"path": "t2.fctb"
"nr": 3,
"path": "t3.fctb"
"nr": 4,
"path": "t4.fctb"
"nr": 5,
"path": "t5.fctb"
"nr": 6,
"path": "t6.fctb"
"nr": 7,
"path": "t7.fctb"
"nr": 8,
"path": "t8.fctb"
"nr": 9,
"path": "t9.fctb"
"nr": 10,
"path": "FR_6.35.fctb"
"version": 1
radius_vogn.FCStd
(11.44 KiB) Downloaded 6 times
Снимок экрана от 2020-01-03 12-31-34.png (207.35 KiB) Viewed 194 times
memfis
Postby memfis » Fri Jan 03, 2020 9:43 am
a good and quick way to find -
grep -ir experimental .FreeCAD/
.FreeCAD/user.cfg: <FCBool Name="EnableExperimentalFeatures" Value="1"/>
memfis
Postby memfis » Fri Jan 03, 2020 10:06 am
don't ask "how" but cheated - my cutter is the default tool, the path is created, but the visualization doesn't work.
What am I doing wrong?
Снимок экрана от 2020-01-03 13-03-41.png (224.43 KiB) Viewed 187 times
вадлмт.FCStd
(18.73 KiB) Downloaded 7 times
radius_vogn.FCStd
(11.33 KiB) Downloaded 8 times
roerich_64
Postby roerich_64 » Fri Jan 03, 2020 12:52 pm
Hi memfis,
looks good your results... :)
Will generate my own ToolBitLibrary. But i can not editing a Tool Bit. When i click on the edit-botton it doese nothing...
Bests
Walter
memfis
Postby memfis » Fri Jan 03, 2020 2:54 pm
Nothing happens to me either when I press this button. Moreover, you can hang on, but not on this button.
I edit simply by opening the file from the Shape folder, then correcting the installation description file in the Bit folder, and after that I add the installation to the library from the Bit folder. Be careful not to confuse the description file with case sensitive letters, which point to the model file in Shape. I suppose that you can use both absolute and relative paths in the description file.
There is no result - yes, the tool has created, I see its real form, it does not affect the form of the created path in any way (and should not), the form of the tool, real, important and necessary for the visualization, which (so far) I have not succeeded.
dubstar-04
Postby dubstar-04 » Fri Jan 03, 2020 3:49 pm
I have started looking at using the new tool definition in simulation:
Simulation.webm
(233.66 KiB) Downloaded 10 times
No material is removed yet as the tool definition need to be modified in the simulation and the position of the tool isn't correct.
Big thanks to mlampert for all your work on these tools.
Thanks,
Dan
