Profile Edges - Why Div by Zero Error?
falviani
Post by falviani »
Here's my setup:
OS: Windows 10 (10.0)
Version: 0.19.18750 (Git)
Hash: a3e88a399fb6395a20f4cf5c7e3ed70e61c9e22f
Python version: 3.6.7
Qt version: 5.12.1
I built a super simple test to see what the effect of the compensation factor was in the profile edges operation. There are 2 20mm squares. One has the profile set to outside, with a -1 compensation; my guess was that the cut would be on the edge. The other has the profile set to inside, with a +1 compensation; again my guess was that it would be on the edge. I keep getting the 'fullsteps = int((start - stop) / size)' zero division error-but I can't figure out what is the wrong value. The freeCAD file is attached - could anyone point out the obvious error I'm making.
I'm afraid I'm finding the UI hard to figure out - the Op values don't seem to match what I'm expecting, and having fake values followed by real values in parenthesis in the depth area of the property pane seems counter-intuitive.
Thanks in advance,
Frank
CompensationTest.FCStd
(31.74 KiB) Downloaded 26 times
mlampert
Re: Profile Edges - Why Div by Zero Error?
Post by mlampert »
Interesting - I don't get that error, a simple recompute seems to produce the correct results. The error looks like you depth is 0, StartDepth == FinalDepth ?
OS: Debian GNU/Linux bullseye/sid (LXQt//usr/share/xsessions/lxqt)
Version: 0.19.18833 (Git)
Build type: Debug
Branch: feature/tool-bit-poc
Hash: 71f1e952a32c389bc6ef6f1a8411c6e43fcaed54
Python version: 3.7.5
Qt version: 5.12.5
falviani
Post by falviani »
Hmm..I just downloaded the latest Win10 nightly:
Version: 0.19.18778 (Git)
Hash: f55cf3ef103532c9718c108bd856a4ef06ad49a5
Qt version: 5.12.1
and the recompute cleared everything up. A transient bug, obviously.
I ran the job and measured the results, getting the results I expected.
