Ticket #4212 - deburr tool crash on vertical faces
freman
Postby freman » Thu Dec 05, 2019 7:13 am
issue #4212
Just found this problem using deburr on a vertically oriented cylindrical surface. May be relevant re. using deburr as a base for vertical surfaces:
https://forum.freecadweb.org/viewtopic.php?f=15&t=41440
The deburr tool seems to "work" for a rectangular, vertical face. However, I'm not sure what this means. I suspect it will cause a tool crash in this example with a countersink tool. See cylindrical-deburr file.
[Edit] confirmed, even with a straight tool the result on a vertical face is clearly wrong and will cause a tool crash. It is creating a path on the face as though it was perpendicular to the tool spindle even though the plane is parallel to the spindle. Ouch!.
OS: Fedora 31 (Thirty One) (LXDE/LXDE)
Version: 0.19.18754 (Git)
Hash: a5019828cf263ccdec3b6885f845b1ab1c35ac11
Python version: 3.7.5
Qt version: 5.12.5
cylinder-deburr-vertical.FCStd
(35.69 KiB) Downloaded 13 times
block-tool-crash.FCStd
(19.07 KiB) Downloaded 11 times
Re: Ticket #4212 - deburr tool crash on vertical faces
Postby Kunda1 » Thu Dec 05, 2019 10:47 am
@fremen Please edit the original post and
1. add ticket number enclosed in the bug bbcode tag
2. add the Help > About FreeCAD > Copy to clipboard info
Thanks.
freman
Postby freman » Thu Dec 05, 2019 1:30 pm
sorry, I put the version info in the bug but forgot to put it here too.
I guess you've got the title the way you want it now.
Postby Kunda1 » Thu Dec 05, 2019 10:04 pm
No worries.
No, I mean use:
[bug]4212[/bug]
example: issue #4212
