Path::3d-surface tool broken?
freman
Postby freman » Fri Dec 06, 2019 7:36 am
I wanted to test 3D-surface tool again and I can't even get a path on a rectangular block.
Surfacing Select Mode
PathOpGui.ERROR: Please select nothing of a solid
Free Select
PathOpGui.ERROR: Please select nothing from a single solid
Once the dialogue is open, where ever I float the cursor in the 3D image shows a no entry icon and the status bar shows "not allowed : " followed by whatever feature I'm over.
If I open a previous file where I had a good 3d path:
  File "/~/freecad-master-qt5-build/Mod/Path/PathScripts/PathOp.py", line 204, in onDocumentRestored
    if FeatureBaseGeometry & features and 'App::PropertyLinkSubList' == obj.getTypeIdOfProperty('Base'):
<class 'AttributeError'>: Property container has no property 'Base'
If I open the path dialogue on the existing 3D path , the toolcontroller and coolant lists are blank.
Is this related to the breakage which happened when toolhandler code no longer worked with py2 builds. Last time I used this tool was with the py2/qt4 build of master in the summer, before that breakage.
Thanks.
OS: Fedora 31 (Thirty One) (LXDE/LXDE)
Version: 0.19.18754 (Git)
Hash: a5019828cf263ccdec3b6885f845b1ab1c35ac11
Python version: 3.7.5
Qt version: 5.12.5
Version: 0.19.18821 (Git)
Hash: 379d04166431517f3eef59c5a55b6e2979562722
Qt version: 5.12.5
Re: Path::3d-surface tool broken?
Postby chrisb » Fri Dec 06, 2019 12:32 pm
I can confirm: Creation of 3DSurface does currently not work.
OS: macOS High Sierra (10.13)
Version: 0.19.18822 (Git)
Hash: 0935aa9f5c446ef493e45abb3eba5ffc1af9f57d
Python version: 3.7.3
Qt version: 5.12.5
Locale: English/Germany (en_DE)
freman
Postby freman » Fri Dec 06, 2019 12:39 pm
Thanks for checking.
Russ4262
Postby Russ4262 » Sun Dec 08, 2019 12:27 am
I'll see if I can take a look over the coming Christmas break.
I've been working on personal coding for education for my classroom; so, I have not been as active here.
Russell
freman
Postby freman » Sun Dec 08, 2019 1:53 am
Hi Russ. Nice to see you are still keeping a watchful eye on all this. I suppose the fact that this is still an experimental add-on means that it never even gets tested against other code changes. Seems to be lots of regressions of late. Sorry I did not get further in looking at the cut direction issues, I seem to spend too much time on maintenance to have enough free time to get into anything deep.
Stay cool down there.
