Update operation base geometry?
falviani
Postby falviani » Mon Dec 09, 2019 6:32 pm
Is there a way to update the base geometry for an operation after it's been "closed"? It would be convenient to add faces or edges, for example, rather than to create many operations or delete and rebuild them. I haven't seen any way to do this.
Thanks in advance,
Frank
mlampert
Re: Update operation base geometry?
Postby mlampert » Mon Dec 09, 2019 7:24 pm
Absolutely, double click on the operation and once the editor shows up in the task panel navigate to the "Base Geometry" tab. You can add/remove features according to the op's selection filter.
