Afternoon Sir,
freman wrote: ↑Wed Mar 18, 2020 6:35 pm
... Look at the attached file. If I change the pad to "reversed" I seem to get return paths INSIDE the stock.
Due to unknown and prolonged issues with the Windows nightly builds, I cannot get paths extracted from FreeCAD files half the time. I don't know what the bug is...
Path workbench activated
Reading failed from embedded file: Job.nc (7236 bytes, 850 bytes compressed)
Reading failed from embedded file: Operations.nc (7236 bytes, 850 bytes compressed)
Reading failed from embedded file: Surface.nc (7236 bytes, 850 bytes compressed)
Nonetheless, what you are experiencing sounds familiar. If a user has a Job based on a source solid, as you do, and updates the source solid, as you did with the reversing of the Pad, then the Job will update the operations in the Job. However, there exists a bug in this process. The Job update fails to update the Stock as well.
So, your fix is to double click on the Job object and click the `Refresh` button in the Stock section of the Setup tab. This should do the trick, re-calculating the Stock, placing it properly around the updated source solid.
Have a great afternoon.
Russ
