Morning, Sir.
Just wanted to offer some ideas to help solve some of your cutting needs on this V-shape with a slot at the bottom - using 3D Surface
- Selecting the internal vertical faces of the notch is not necessary. They have no effect on the 2D cut area created from the face selection.
- Strategy: Select the two V angle sides and the bottom of the slot. Set the depth to the bottom of the V angle sides. This will clear the bulk of the shape, leaving only the notch to be cleared.
- Select only the bottom face of the notch and setup the 3D Surface operation, lowering the Start Depth down to the bottom of the V angle sides. Run the operation and change the `CutPatternAngle` to 90 degrees. This gives the single line path down the middle of the slot to clear it.
- Yes, a combination of 3D Surface and other 2.5D ops is a great solution for some scenarios.
Russ
