3D Surface - Face Selection (New feature) [Merged]
freman
Re: 3D Surface - Face Selection (New feature)
Postby freman » Mon Feb 24, 2020 5:37 pm
For lines this can currently be achieved by rotating the workpiece by 180° when generating paths but that is a little inconvenient and doesn't work for circular features.
Thank you very much,
jffmichi
Modifying the model I posted above, I now set start depth= -10 ; finish depth=0 ; step down= -1 and the paths are done in reverse order. Test with your circular features ...
new version attached.
slope-reverse.FCStd
(28.41 KiB) Downloaded 6 times
Postby chrisb » Mon Feb 24, 2020 6:18 pm
Great idea! And it shows why I don't like too many system restrictions forbidding to set values which seem on first sight to be nonsense, such as stepdown being negative.
freman
Postby freman » Mon Feb 24, 2020 6:26 pm
Well my boundaryDressUp PR to allow negative boundaries got merged last week. I admit I was half expecting this not to be allowed as I tried it and was pleasantly surprised. Kudo -> Russ.
I just checked this in the sim and it is actually a bit weird because it still does the layers from top down even though I seem to have told it to start at the bottom. It's really handy in that it does just what was wanted but it seems to be a bug that it does so. :?
I also noted that it does unnecessary repeats on the upper steps, it seems that it produces multiple passes at the correct depth for the surface , so the top step gets machined a dozen times. All the steps get the same number of passes even though they have different heights. Probably just a tweak to the code required there.
Postby chrisb » Mon Feb 24, 2020 6:55 pm
Did you check the GCode? I would not bet on the simulation.
Postby chrisb » Mon Feb 24, 2020 6:59 pm
If I try to set the values for bottom up milling I get the message "z_finish_step must be less than step_down" in report view. Perhaps you got this too and due to the error you still see the old paths?
freman
Postby freman » Mon Feb 24, 2020 10:39 pm
I do not see any warnings and I looked at the arrows on the 3D view to see path reversal.
You are correct to say I should not trust the sim, but looking at the Gcode it seems to be consistent. You have my FCStd file for the reversed version above, maybe you can check there is no contradiction with what I'm seeing.
Path workbench activated
Wizard shaft module cannot be loaded
Path workbench deactivated
grbl_post: GCode postprocessor loaded.
Surfacing Select Mode
PathSurface.INFO:
Begin 3D Surface operation...
PathSurface.INFO: Operation time: 1.3144962787628174 sec.
PathSurface.INFO:
PathSurface.INFO: Operation time: 0.8370604515075684 sec.
Free Select
PathSurface.INFO:
PathSurface.INFO: Operation time: 1.4129679203033447 sec.
PathSurface.INFO:
PathSurface.INFO: Operation time: 1.4213645458221436 sec.
PathSurface.INFO:
PathSurface.INFO: Operation time: 1.4202876091003418 sec.
Free Select
Free Select
PathSurface.INFO:
PathSurface.INFO: Operation time: 1.436408281326294 sec.
PathSurface.INFO:
PathSurface.INFO: Operation time: 1.4854810237884521 sec.
Free Select
PathSurface.INFO:
PathSurface.INFO: Operation time: 1.4308133125305176 sec.
PathSurface.INFO:
PathSurface.INFO: Multi-pass op has 57 layers (step downs).
PathSurface.INFO: Operation time: 2.9565913677215576 sec.
Free Select
PathSurface.INFO:
PathSurface.INFO: Multi-pass op has 12 layers (step downs).
PathSurface.INFO: Operation time: 1.656735897064209 sec.
Free Select
PathSurface.INFO:
PathSurface.INFO: Operation time: 1.6638684272766113 sec.
Free Select
PathSurface.INFO:
PathSurface.INFO: Operation time: 1.7897915840148926 sec.
post: grbl(/back/tmp/cnc/slope-rev.nc, --translate_drill)
Post Processor: grbl_post postprocessing...
Done postprocessing.
OS: Fedora 31 (Thirty One) (LXDE/LXDE)
Version: 0.19.19591 (Git)
Branch: 3D
Hash: 27771fc6ee93170b6ecb978ff4da438a5b9cfe97
Python version: 3.7.6
Qt version: 5.13.2
Postby chrisb » Mon Feb 24, 2020 10:47 pm
I opened your file from this post:
It doesn't show a path, and a full recompute shows this in report view:
Reading failed from embedded file: Job.nc (46547 bytes, 2029 bytes compressed)
Reading failed from embedded file: Operations.nc (46547 bytes, 2029 bytes compressed)
Reading failed from embedded file: Surface.nc (46547 bytes, 2029 bytes compressed)
  File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathUtils.py", line 59, in new_function
    res = function(*args, **kwargs)
  File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathOp.py", line 513, in execute
    result = self.opExecute(obj) # pylint: disable=assignment-from-no-return
  File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathSurface.py", line 368, in opExecute
    final = self._planarDropCutOp(obj, stl, bb)
  File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathSurface.py", line 438, in _planarDropCutOp
    dep_par = PathUtils.depth_params(obj.ClearanceHeight.Value, obj.SafeHeight.Value, obj.StartDepth.Value, obj.StepDown.Value, 0.0, obj.FinalDepth.Value)
  File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathUtils.py", line 734, in __init__
    raise ValueError('z_finish_step must be less than step_down')
<class 'ValueError'>: z_finish_step must be less than step_down
4.1e-08 <App> Document.cpp(3464): Failed to recompute slope_reverse#Surface: z_finish_step must be less than step_down
Recompute failed! Please check report view.
Perhaps I should wait for the next version?
OS: macOS High Sierra (10.13)
Version: 0.19.19694 (Git)
Hash: 288456ee4beb9e8dc27d50a7984c40c45467161f
Python version: 3.8.1
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
freman
Postby freman » Mon Feb 24, 2020 11:19 pm
Are we using the same version of Russ' script?
__scriptVersion__ = "9d"
__lastModified__ = "2020-02-12 10:42 CST"
I downloaded from top post here.
https://forum.freecadweb.org/download/f ... ?id=103797
Postby chrisb » Mon Feb 24, 2020 11:48 pm
Oops, I thought it was already in master.
It doesn't work here even if I exchange the file, so there is probably the other file too, which has to be exchanged. I think I should leave it as it is, it works in your version, and I can wait until we have it in master too.
Postby chrisb » Mon Feb 24, 2020 11:52 pm
Couldn't resist and replaced all files, PathSurfaceGui.py, PathSelection.py, PathSurface.py. Same error as before, perhaps some other version clash. I can wait.
