3D Surface - Face Selection (New feature) [Merged]
Re: 3D Surface - Face Selection (New feature)
Russ... This is amazing. Unfortunately i cannot show you anything to encourage you but know that this is great for laser milling!
Looking at the overhang it seems 3D surface creates an undercut, which would cut the tip with an endmill:
- Bildschirmfoto 2020-02-11 um 19.21.10.png (45.73 KiB) Viewed 1002 times
Okay. I think these issues are resolved, and I was able to consolidate more code. Win, win! Well, I say "resolved." Really they are working for the models I am testing. LOLRuss4262 wrote: ↑Tue Feb 11, 2020 4:40 pm I can already see a couple bugs that needs to be corrected....
- I see the hexagonal extrusion does not have a profile path around it.
- I see the profile around the through hole on the right side does have an extrusion, but I think the intended behavior with the current settings should push the profile farther into the hole, creating an overhang like that on the outside perimeter of the model.
I think it is time for more testing. I also need to go through the code to add and correct docstrings for the many new methods - although most are custom for 3D Surface and not intended for external use/reference.
Russ
- 3D_Surface-Version 9a - Respect boundary is False - fixed.png (229.72 KiB) Viewed 978 times
Please forgive my ignorance and lack of real CNC experience. I don't think I understand exactly what you are getting at. Is your statement a good thing or bad? If bad, what approach or changes are common place to avoid such a negative situation. Can you add illustrations to the image to highlight the condition or area to which you are referring?
If a positive thing, then great!
Thanks, ChrisB
Hi Russ.
I can not see an overhang in your models, so I don't know what he was pointing to.
I looks like it may be a perspective problem: there are two ways to read a 2D view of a 3D object and what can be interpreted as an over-hang is in fact the V-cut in the block, not an overhang.
However this is something you probably should test for. I suggest you create a model with an overhang and see what 3Dsurface does with it.
The 2.5D tools can do pretty silly things sometimes:
https://forum.freecadweb.org/viewtopic. ... 69#p352447
That's pretty blatant and no one would run it, but there could be less obvious geometries where a slight overhang would lead to a tool crash. I think that's what Chris was suggesting was happening here. It's worth investigating what your tool will do. Maybe a near vertical plane inclined at 91 deg. , would it try to undercut it, or just not produce a path below the upper edge?
I meant something not good, but from your last image I think I made some noise about nothing - which can be seen as good.
I had thought that there were paths under the overhang milling the diagonal, I tried to fake it:
- Snip macro screenshot-245e58.png (16.18 KiB) Viewed 949 times
There is no overhang Chris, it's a V-cut in the top face. These isometric images play havoc with my brain too. I keep seeing the hexagonal pad as some kind of complicated pocket. Once the brain locks into one interpretation it can be hard to flip it around.
Here's a photo of recently discovered cave art in Spain. It took me 10 minutes to see those marks as gouges, not relief marks.
But it would be good to test the new tool on a model like what you just posted and the model I posted. Here's the model , if it's of any use.
- block-faces.FCStd
- (34.26 KiB) Downloaded 36 times
Here is a stress test model I submitted to sliptonic's CNC-torture collection.
Russ, you may like to throw a 3D over that and look at accuracy where the squares and circles touch. This brought out a bug in one of the 2.5D tools which did not handle a zero dimension correctly.
There should be an unbroken vertical line from the corners of the top square down to the base, touching both cuboids and the cylinder.
- diamond-circ-sqr.FCStd
- (11.49 KiB) Downloaded 39 times
Morning Freman,
Thanks for suggesting such a check!
I haven't gotten around to checking the other file you suggested for a test case.
Russ.
3D Surface catches overhangs every time because Dr. Wallin's OCL is a drop cutter algorithm. I ran the file anyway and did discover a tweak I think we'd like to have. In the attached, I set the new `AvoidXFaces` to the top face of the overhanging geometry, but I didn't get the expected result. The operation still generates a path on top of the overhanging face. Ideally, I think we do not want that. I'll take a look at the `AvoidXFaces` algorithm and see where I need to tweak it to produce the desired behavior. Ideally, in this scenario, I think we would only want/expect a path generated in the front left rectangular region of the selected yellow face. Correct?
Russ.
- 3D_Surface-ver9c-overhang-1.png (191.08 KiB) Viewed 917 times
Fixed.Russ4262 wrote: ↑Wed Feb 12, 2020 4:03 pm Morning Freman,3D Surface catches overhangs every time because Dr. Wallin's OCL is a drop cutter algorithm. I ran the file anyway and did discover a tweak I think we'd like to have. In the attached, I set the new `AvoidXFaces` to the top face of the overhanging geometry, but I didn't get the expected result. The operation still generates a path on top of the overhanging face. Ideally, I think we do not want that. I'll take a look at the `AvoidXFaces` algorithm and see where I need to tweak it to produce the desired behavior. Ideally, in this scenario, I think we would only want/expect a path generated in the front left rectangular region of the selected yellow face. Correct?
The recent code restructuring helped make the code easier to maintain. That time consuming task is paying off.
Russ
- 3D_Surface-ver9c-overhang-1-fixed.png (185.66 KiB) Viewed 913 times
