is opToolDiameter a sensible default
what is the basis of the default cut depth of being equal to the tool width.
This is a pretty heavy cut and while commercial machines in a production environment will do this, is it really the best "default" value.
Today I had to recreate a path that I had previously configured and somewhere along the way I forget to set the the stepdown value. I had an 8mm tool and so it used 8mm depth by default. Luckily I only had 5mm to take off so I got a 5mm deep cut. It was a profile using spiral so the first cut is basically an 8mm slot which runs around the finished edge.
now 8mm slot 5mm deep is a lot of metal, it did not break anything ( to my relief ) but it howled a lot and gave a pretty rough finish.
I wonder if this is really a sensible default. A default should work by default, it is not a production optimised cut. Would a more conservative value be better for "default", in the sense that default works without danger in the "fault" of not having a specified valued.
Re: is opToolDiameter a sensible default
This looks to me highly dependent on which material you're machining. Polystyrene isn't 100C6 steel. So hard to define what is a good value.
Also notice that Path issues are better handled in the Part subforum.
thanks OB, I realise there are a lot of factors, but polystyrene is not very good default material.
IMO a default should be a safe all round value which the user can then tweak according to knowledge of the material and machine in question. Tool o/d as cut depth looks like a pretty hardcore option for most materials.
did you mean the Path subforum there. I posted here first since maybe I was missing something and did not want to get shouted at for posting a dumb question in a dev forum.Also notice that Path issues are better handled in the Part subforum.
Yep. Path (as FEM and Techdraw) discussions are better placed in its own dev subforum.
Moved to Path forum.
I think mlampert has already recommended this to you: You can use your own templates for job generation. Nevertheless I too think that the default could be a bot more conservative.
Totally agree!
Machinery is dangerous: FAIL-SAFE, and error on the side of conservancy!
Everyone does not use, or want to use job templates; especially for one-off machining.
I would rather start in safe condition JUST in case.
3mm or 1/8 inch is more realistic as a starting default. Then from there, do all the damage you please!
Yet this subject still lingers and continues to be questioned; ever wonder why?
BTW, what chuck capabilities are these defaults based on, 8mm key-less, collet, morse taper, etc,, etc.
3mm would break every bit I have on any operation I perform unless I start working in foam which would be pointless to me. The fact is there is not a single safe value unless we use 0 (which doesn't work for other reasons).
The reason it is the tool diameter is because all chip load charts are keyed by the tool diameter.
yes, clearly this is correctly related to tool diameter but 100% is not a safe starting point.
I tend to use 25% when I don't forget what I'm doing but I asked for those with more trade experience to chip in ( no pun ).
In practice this is something you will almost always need to set for the job , so using default probably means you forgot. Maybe 10% would be a safer starting point for those senior moments.
Of course this has to be depending on the diameter. Nobody will mill with a depth of 3mm with a 1mm mill and with a 30mm mill it well can be more. When I said to be more conservative I was thinking about 1/3 or 1/4, but even these values are rather deliberate. I thought about asking to put them directly in the preferences, but for which material? So I think it is a good solution to have templates, e.g. for different materials and different mills.
And if common charts use 1/2 or 1/1 we should use it too. If a newbie downloads FreeCAD, creates some model, generates a path, loads it on the machine, and starts milling right away without ever having checked - e.g. by milling in plain air - I would say he is not courageous, he is an idiot.
Some tima ago sliptonic explaned why this default tool is there and why other default settings are not 0: Its a need for the calculation of the path, because if no tool is there and/or it's default is 0, it runs in an "division by zerro" error somewhere.
I'm not a friend of this default settings, because they are at 99.xx% of the cases wrong. I'm with you, if you say "if it's a need for it, set it to a save value". - But what's a save value? One say 25% of diameter, one 10%... But what if we have a usecase which comes not in our mind atm.?
I think we should accept, that the milling parameters are not save and we have to check it each time we create a path.
Partial savety is more dangerus as no savety in this case. If there are no save settings, the user is carefull for all things. If there a some things save, others not, it comes to mistakes like "oh, i thought this setting is safe"...
Gruß Herbert
