G-code for rounded edges
OS: Debian GNU/Linux 10 (buster)
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.18.
Python version: 2.7.16rc1
Qt version: 5.11.3
Locale: Russian/Russia (ru_RU)
Hi !
I need to sharpen a rectangular part with rounded edges.
I create a rectangle with rounded corners in the sketch, then squeeze it out and round the edges in 3D. I go to Path-workbench -> 3D Pocket object and try to draw g-code paths in It. In "Depths" set point of Z-zero surface top, -4mm-finish, step 0.1 mm.
The problem is that the paths do not draw the entire rounding geometry, but only part of it, as in the screenshot.
What am I doing wrong ?
Version: 0.18.
Qt version: 5.11.3
Hi !
- CNC_3.jpg (3.58 KiB) Viewed 1243 times
- CNC_2.jpg (101.77 KiB) Viewed 1243 times
- CNC_1.jpg (226.86 KiB) Viewed 1243 times
Re: G-code for rounded edges
Please retry with the next published version of 0.19. There are important improvements in the queue for 3D pocket.
I try install 0.19 to windows. It work still worse.
I think you installed the current and not the next published version. However, you can replace some Python files to get the current development stuff, see https://forum.freecadweb.org/viewtopic.php?f=15&t=41997.
The new tool of 3D operations is activete ! - "Surface"chrisb wrote: ↑Tue Jan 28, 2020 11:23 am I think you installed the current and not the next published version. However, you can replace some Python files to get the current development stuff, see https://forum.freecadweb.org/viewtopic.php?f=15&t=41997.
but...
This operation need OpenCamLib
How install OpenCamLib in Linux (Debian) ?
You can use the AppImage, where opencamlib is included, or compile it yourself. That's what I did on Ubuntu, so it should work on Debian too.
I'm sorry, I was always thinking you were talking about 3D sufrface, although you clearly said 3D pocket. Probably because I recently have looked quite some time on 3D surface. You may retry after adding a bottom plate to the model, that's what I usually do with 3D pocket.
BTW: You have emptied a post above. You can delete a post yourself as long as it's the last post in the topic.
Thank you for answer.chrisb wrote: ↑Tue Jan 28, 2020 6:02 pm You can use the AppImage, where opencamlib is included, or compile it yourself. That's what I did on Ubuntu, so it should work on Debian too.
In the first time was only "3D-pocket". After set parameter (Tool - Editor - Preferences - Mod - Path - EnableExperimentalFeatures - Boolean - True), activate "3D sufrface".
Unfortunately the tool "3D sufrface" issues error.
AppImage I install from Synaptic (libaapimage-dev and libappimage0).
Problem is not solved.
I don`t know how delete message from forum.
P.S.
Using 3D sufrface I receive Error:
Red text below "This operation need Install of OpenCamLib"
- CNC_5.jpg (36.68 KiB) Viewed 1153 times
- CNC_4.jpg (207.94 KiB) Viewed 1153 times
- CNC_3D.jpg (12.18 KiB) Viewed 1153 times
You find the current AppImage here: https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre.
The new 3D surface is not in Master yet.
Moved to Path forum.
