G-code for rounded edges
m0n5t3r
Re: G-code for rounded edges
Postby m0n5t3r » Thu Feb 27, 2020 11:17 am
Looks like you don't have opencamlib
If you're proficient with the command line there is an opencamlib deb package source here: https://salsa.debian.org/m0n5t3r-guest/opencamlib (I was asked to submit a merge request, did it, no response so far, I guess kkremitzki is a lot busier than me)
You can clone it, install build dependencies and run
fakeroot debian/rules binary
which will build a python3-opencamlib deb package - I tested this in a debian unstable container before sending the merge request, should work in buster too.
I'm not sure the appimage thing can use it, though (never used it, if it's something along the lines of snap and flatpak it will have its own container-like isolation environment and won't be able to use the system python libraries).
