New feature: ProfileEdges - Cut open edges [Merged]
dubstar-04
Re: New feature: ProfileEdges - Cut open edges
Postby dubstar-04 » Wed Feb 26, 2020 8:15 pm
Postby chrisb » Wed Feb 26, 2020 9:58 pm
Many thanks - while waiting for the next build!
Russ4262
Postby Russ4262 » Wed Feb 26, 2020 10:05 pm
Afternoon Dubstar-04,
You and the FreeCAD community are welcome. I hope it finds some use.
Merged!!
https://github.com/FreeCAD/FreeCAD/comm ... 8bbcfb74dc
\0/
Thank you Russ!
@Sliptonic
sliptonic wrote: Ping
I plan on revisiting the updated op to apply some performance-improving-code-substitution knowledge gained yesterday evening in the chatroom. I do not intend to add features, other than consider activating the `CutSide` property for the new open edges capability, for the purpose of maintaining flexibility in use cases.
On a separate, but ProfileEdges related topic,
I can see definite application of strategies developed in this upgrade that will work well with 2D applications, like shape strings that have no depth, or SVG files that are used for 2D part design.
Okay. I better stop thinking about this, and where it leads. I'll never get away from the computer terminal to power up my own CNC for projects with my children.
Back to 3D Surface...
Glad to be on board the SS FreeCAD with such a crew.
Cheers,
Russ
Postby chrisb » Wed Feb 26, 2020 10:18 pm
Glad to have you on board - while we are still struggling to get out of the water.
dubstar-04
Re: New feature: ProfileEdges - Cut open edges [Merged]
Postby dubstar-04 » Thu Mar 26, 2020 1:28 pm
Hi Russ,
I am trying to use the profile open edges on the attached model. For some reason it seems to fail on every edge I have tried.
I would like to run a finishing endmill down a few of the edges to clean up after roughing:
The result:
Any ideas?
Thanks,
Dan
OS: Debian GNU/Linux 10 (buster) (GNOME/gnome)
Version: 0.19.20238 (Git)
Build type: Unknown
Hash: 9f766102f697f9f98a9ba0bd6cbc6b99c55fbb9b
Python version: 3.7.3
Qt version: 5.11.3
ViceClamp.FCStd
(130.21 KiB) Downloaded 5 times
Russ4262
Postby Russ4262 » Thu Mar 26, 2020 3:15 pm
Hi Russ,
It appears the cause is that the `GeometryTolerance` property in the `Job` is set to zero. Click on the `Job` once to select. Scroll through the properties in the Data tab. Change `GeometryTolerance` to an acceptable value. Re-run your ProfileEdges operation(s).
NOTE: I did find that compound selections in some places returns invalid paths. To solve, reduce the compound selection to fewer consecutive edges, or group them differently - in smaller groups.
UPDATE 2020-03-26 CST - Submitted PR - [Path] Fix failed open edge path for zero GeometryTolerance case #3266. The fix is to inform the user of a zero value for Job.GeometryTolerance and that it needs an acceptable value greater than zero.
Cheers,
Russ
