playing with Path 3Dsurface
sibelius
Postby sibelius » Fri Feb 21, 2020 12:25 am
OS: Windows 10 (10.0)
Version: 0.19.19290 (Git)
Hash: 2f0d34e0ffd68883fce04374844d519903e0c305
Python version: 3.6.8
Qt version: 5.12.1
_________________________________________________
Hi everybody.
I made this small file with the intention to test my cnc.
The "problem" I find is that when I simulate the Path of the mill I can't really see if the final result would be good or not.
Anyway I share my file and if someone likes to play too, maybe can give some advice.
Thank you very much in advance.
Here is my file https://we.tl/t-SuIT1r3vOa
Re: playing with Path 3Dsurface
Postby Kunda1 » Fri Feb 21, 2020 4:04 am
Moved to Path subforum
Please add your FC About info to the OP
RatonLaveur
Postby RatonLaveur » Fri Feb 21, 2020 1:47 pm
Hi, to my knowledge it is a known limitation of the simulation environment of Path WB that 3D paths are not ideally visualized. The main reason for that is that the virtual tool is a straight cylinder, not a ball mill. The calculation of the volume was also simplified accordingly.
At the moment there is no specific remediation unfortunately. When going for path troubleshooting, polystyrene blocks or florist foam are the best "crash free" test pieces.
sibelius
Postby sibelius » Fri Feb 21, 2020 10:19 pm
Thank you very much for your reply.
I had the feeling that's was the case.
Anyway thanks again.
cron
