G-code for rounded edges
rainbowhope
Postby rainbowhope » Thu Feb 27, 2020 10:25 am
OS: Debian GNU/Linux 10 (buster)
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.18.
Python version: 2.7.16rc1
Qt version: 5.11.3
Locale: Russian/Russia (ru_RU)
Hi !
I need to sharpen a rectangular part with rounded edges.
I create a rectangle with rounded corners in the sketch, then squeeze it out and round the edges in 3D. I go to Path-workbench -> 3D Pocket object and try to draw g-code paths in It. In "Depths" set point of Z-zero surface top, -4mm-finish, step 0.1 mm.
The problem is that the paths do not draw the entire rounding geometry, but only part of it, as in the screenshot.
What am I doing wrong ?
P.S.I discussed this problem on the forum, but without result.
https://forum.freecadweb.org/viewtopic.php?f=3&t=42833
Re: G-code for rounded edges
Postby chrisb » Thu Feb 27, 2020 10:31 am
How about following the advice in the linked topic and try 0.19? The changes to 3D surface have been committed and will soon (or already) be in the available versions.
Edit: Moved to Path forum.
dubstar-04
Postby dubstar-04 » Thu Feb 27, 2020 10:41 am
depending on the radius; You could also think about using a corner rounding tool:
Thanks,
Dan
rainbowhope
Postby rainbowhope » Thu Feb 27, 2020 11:09 am
I put 0.19 on windows. Not help.
rainbowhope
Postby rainbowhope » Thu Feb 27, 2020 11:28 am
Thanks,
Dan
Using a shaped cutter restricts the sample shape. I am interested in forming the edge shape in the FreeCad editor .
Postby chrisb » Thu Feb 27, 2020 11:51 am
Which 0.19? Please add your full FreeCAD info augmented by the date shown on the dialog.
Postby chrisb » Thu Feb 27, 2020 12:01 pm
I just downloaded 0.19.19717. The new 3D-Surface stuff is not contained. We will have to wait for the next build.
rainbowhope
Postby rainbowhope » Thu Feb 27, 2020 12:49 pm
1) Are you from the development team?
2) When is the new build planned?
OS: Windows 7 SP 1 (6.1)
Version: 0.19.19373 (Git)
Hash: c47512b7b2b3b64b4a21a86ad34a565459a13e6a
Python version: 3.6.8
Qt version: 5.12.1
In the attached files, the project and description of the version of FreeCad for Windows. The windows is in office. But more often I use Linux by Debian 32 bit.
For Debian only 0.18
FreeCad_019.txt
(310 Bytes) Downloaded 1 time
1.FCStd
(23.54 KiB) Downloaded 1 time
dubstar-04
Postby dubstar-04 » Thu Feb 27, 2020 1:14 pm
Hi Chris,
I'm not sure that the 3D surfacing has been merged yet: https://github.com/FreeCAD/FreeCAD/pull/2849
Thanks,
Dan
herbk
Postby herbk » Thu Feb 27, 2020 1:21 pm
Hi together,
i think there is still the need to enable the experimental features for 3D Surface OP...
3D Surface works for me, but there are a few things to know:
1. For a smooth path you have to reduce the sample interval to 1 or less. The time to calculate the path incrases, but path is good...
2. If you want to work at each side of your workpeace you have to extend the BoundBox extra Offset.
If change the settings i get this output which works at the machine (LinuxCNC) like expected:
OS: openSUSE Leap 15.1 (KDE//usr/share/xsessions/plasma5)
Version: 0.19.19691 (Git) AppImage
Hash: 361acd5a8405139aed3fbf7036bd76d2ca273cd0
Python version: 3.8.1
Qt version: 5.12.5
OCC version: 7.4.0
Gruß Herbert
