Dressup improvements (Deburr, LeadInOut)
i noticed 2 things with dress ups.
1. If you disable a op with dressup, the dressup doesn't change its color. If you don't expand the dressup, it still looks active.
2. LeadInOut doesn't work with deburring. Creates strange paths.
BR
BR
- dubstar-04
Re: Dressup improvements (Deburr, LeadInOut)
Confirmed and reported:
https://tracker.freecadweb.org/view.php?id=4280
Thanks,
Dan
OS: Windows 10 (10.0)
Version: 0.19.19635 (Git)
Hash: 757cfce10b87ca087d31ce38eb30f612bf55fcad
Python version: 3.6.8
Qt version: 5.12.1
Thanks,
Dan
Qt version: 5.12.1
- LeadINTest.FCStd
- (35.73 KiB) Downloaded 46 times
Hey dubstar-04 just a quick FYI that you can add bugs using the bug bbcode
it will automatically link to the bug without the need for the URL.
[bug]4280[/bug]
issue #4280
I'm currently working on it. Already fixed the problem halfway.
Only one problem remains: the staring point.
Currently the operation takes the starting point of the op, but if it's a "bad" position like the corner in this example, it creates a wrong path.
BR
BR
- deburr1.png (18.56 KiB) Viewed 2131 times
Submitted PR https://github.com/FreeCAD/FreeCAD/pull/3132
1. Fixed faulty path with LeadInOut Dressup for Deburr Op. First move of DeburrOp was a plunge (no X and Y coords specified). Dressup assumed entry point as 0,0.
2. LeadInOut Dressup calculated wrong direction, so i added "Side"-Attribut to OP, which is automatically assigned (but can be changed manual)
3. If the entry point of the deburr op is at an infelicitous point, path was also not correct. So i added the option "EntryPoint" to Deburr Op. Now you can choose the segment, where the op starts.
mfg
mfg
- deburr3.png (61.88 KiB) Viewed 2109 times
Is this applicable to other ops?
The segment selection for entry point is a good addition in my book. Will really start allowing these energy beam (AWJ, Laser, Plasma...) Paths to be used with FreeCAD more effectively.
- dubstar-04
I forgot about that!Kunda1 wrote: ↑Thu Mar 05, 2020 7:22 pmHey dubstar-04 just a quick FYI that you can add bugs using the bug bbcode
it will automatically link to the bug without the need for the URL.becomesCode: Select all
[bug]4280[/bug]
issue #4280
Thank you
- dubstar-04
Wsk8 wrote: ↑Thu Mar 05, 2020 10:11 pm Submitted PR https://github.com/FreeCAD/FreeCAD/pull/3132
mfg
Thanks for this!!
While you are looking at this dress up would you be able to extend its functionality to work with the profile single edges operation?
It would benfit from having an 'extend' option that simply extended the start and end segments to allow cleaner lead in and lead out for single edge operations.
Thanks,
Dan
No, the deburr op depends only on engraving. For other ops it must be implemented separatly.
I will see what i can do.dubstar-04 wrote: ↑Fri Mar 06, 2020 8:23 am While you are looking at this dress up would you be able to extend its functionality to work with the profile single edges operation?
mfg
Added Extend LeadIn option:
Arcs are now entered in correct angle:
br
br
