Request for help - cutting clamp lips
falviani
Postby falviani » Thu Mar 26, 2020 7:30 pm
Hello all
My setup:
OS: Windows 10 (10.0)
Version: 0.19.19758 (Git)
Hash: c165edd52c7f06ac09f992e5b5bf1d37661a8c0f
Python version: 3.6.8
Qt version: 5.12.1
I have designed a clamp for my CNC I wish to cut out of 3/4" oak, using a single 1/4" flat end mill. My problem is that I can't figure out how to cut the step lips that will mate with a brace to keep the block horizontal when screwed into position. The design looks like this:
I thought that a pocket operation would do what I need, but the simulation does nothing. What do I need for this - I really don't want to use 2 different bits.
Thanks in advance,
Frank
CNC Clamp.FCStd
model
(96.75 KiB) Downloaded 8 times
herbk
Re: Request for help - cutting clamp lips
Postby herbk » Thu Mar 26, 2020 8:05 pm
Hi Frank,
your tool is to big. The Poket OP (other OPs to) works only if the face to mill is in x and y direction bigger as the tool diameter.
Gruß Herbert
Postby Kunda1 » Thu Mar 26, 2020 8:10 pm
If you are going to use the development version, especially for Path, please keep it updated with the latest development version. Current is r20286
herbk
Postby herbk » Thu Mar 26, 2020 9:00 pm
You can use the Deburr OP for the steps.
CNC Clamp_herbk.jpg (57.64 KiB) Viewed 184 times
CNC Clamp_herbk.FCStd
(96.39 KiB) Downloaded 22 times
Gruß Herbert
Russ4262
Postby Russ4262 » Fri Mar 27, 2020 4:17 am
Evening, Sir.
...What do I need for this - I really don't want to use 2 different bits.
Thanks in advance,
Frank
If you will grab the latest nightly build, I think your needs could be met by the recent upgrade of ProfileEdges to cut open edges. Just select the top edge of the riser for each step, set the final depth, and it should work. You might be able to select the bottom edge and forego setting the final depth.
I'm on a mobile, so I can't test for you tonight.
Cheers,
Russ
falviani
Postby falviani » Fri Mar 27, 2020 11:51 am
Thanks - I'll give that a shot later this afternoon. :D
Russ4262
Postby Russ4262 » Fri Mar 27, 2020 11:32 pm
Afternoon to you in the Southern Hemisphere.
I ran the ProfileEdges operation on the steps, selecting one bottom edge of the vertical riser at a time (one operation per step). Selecting the bottom edge allows for not setting the final depth, but may not work in all situations. It works. I tried multiple steps combined and errors arose!
The paths are partially hidden by the model geometry, but they are there, hence the second image.
Cheers,
Russ
CNC Clamp_A-1.png (162.7 KiB) Viewed 66 times
CNC Clamp_A-2.png (133.24 KiB) Viewed 66 times
