Bizarre Generated Code from Millface Operation?
falviani
Re: Bizarre Generated Code from Millface Operation?
Post by falviani »
FreeCad:
OS: Windows 10 (10.0)
Version: 0.19.20477 (Git)
Hash: 7d8ab175a68e476427e6e337fe3099b52da49dc8
Python version: 3.6.8
Qt version: 5.12.1
1) Reload file and recompute.
2) Use --no-show-editor
3) Export to gcode.
4) Step down is still 0.5mm
No change - output file is still 1053K,
I also tried doing a separate file, using a path pocket operation with almost identical parameters (1mm stepdown rather than 0.5 mm). Also produced 1053K File. Attached. A first guess is that they're both using the same algorithm, but I have no evidence for that.
WasteBoard_PocketSurface_1mm.FCStd
(242.47 KiB) Downloaded 23 times
falviani wrote: Thu Apr 09, 2020 9:51 pm 1) Reload file and recompute.
You either did something different from your description or you didn't upload the right file. --no-show-editor is not set.
I have the same situation as before:
- Loading your file and directly exporting GCode takes 10 minutes to show in the editor and creates a 28000 lines file.
- doing a full recompute before doing the rest in the same ways results in a file of 200 lines without noticeable time lag.
OS: macOS High Sierra (10.13)
Version: 0.19.20406 (Git)
Hash: bb45a2b01f9aafeae00cdf60c87b43fc36ad28ad
Python version: 3.8.2
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Locale: C/Default (C)
What happens if you inspect the GCode? If you mark the lines you should see the coloured mill paths.
falviani
Post by falviani »
I double checked twice and the --no-show-editor argument is definitely set. The file is attached. Also, I had started running the simulator - and it had repeated the paths more than twice - when my wife called for dinner. When I came back roughly 35 minutes later the simulator was still running. The saved file from this with the correct time stamp was still 1053 KB. I can't think of anything else.
SurfacingTest.FCStd
(217.72 KiB) Downloaded 28 times
Russ4262
Post by Russ4262 »
I can reproduce the results with MillFace. I have not tested the other PathAreaOp-based operations. Yes, @FAlviani, MillFace and PocketShape use the same algorithm, Path.Area().
I did notice that changing the OffsetPattern to Line, Spiral, or Triangle removes the repetitive gcode issue. This suggests the problem is in Path.Area(). Further testing confirms problem is post-20276 nightly. Suggests recent Path.Area() commit on 5 April might be the issue. Running personal test file on 20276 yields correct g-code for inspection. 20477 produces erroneous g-code.
Russ
m0n5t3r
Post by m0n5t3r »
Sorry, I got thrown off by the initial post saying it's 1050 MB (not kB) and didn't look closer
The issue seems to be with whatever is generating the zigzag:
  • zigzag goes back and forth forever (edit: like it's missing a stop condition or something; I thought maybe it was a rounding error on finish depth, but if you set finish depth to non-zero it does the same)
  • offset does a single pass; if you also make it keep the tool down, it's pretty efficient
  • zigzagoffset does the perimeter, then zigzag printer goes brrr (same as zigzag on its own)
  • spiral is as broken as ever
  • line works, does a single pass; with keep tool down it's almost like zigzag, but with a 3d printer-ish way of sorting paths
  • the weirdo options (grid and triangle) also work correctly (I assume the results are pretty if you surface something shiny)
dubstar-04
Post by dubstar-04 »
m0n5t3r wrote: Fri Apr 10, 2020 5:23 am
[*] the weirdo options (grid and triangle) also work correctly (I assume the results are pretty if you surface something shiny)
The weirdo options! Ha ha, that has made my day. :D
We should vote on removing them from the options.
Thanks,
Dan
falviani wrote: Fri Apr 10, 2020 12:07 am I double checked twice and the --no-show-editor argument is definitely set.
Yes, here it is. And as to be expected after Russ' post, it still behaves the same. If you urgently need some GCodes - e.g. because if you cannot get to your mill you go on the nerves of your wife - you may upload the final file, and someone here will recompute it.
Russ4262
Post by Russ4262 »
Paging Dr. RealThunder
realthunder wrote:ping
I think the recent change to Path.Area() might be the culprit for the issue experienced here. When you have time, will you please check. I went back to 20276 release last night and the issue does not occur. I'm using 20477 and I have the issue experienced here, like @falviani and @m0n5t3r.
Thank you, Sir.
Russ
falviani
Post by falviani »
It's not urgent - I have my wasteboard surfaced adequately. But I wanted to point out a problem. Now that others have reproduced it, I'm confident it will be tracked down and squashed quickly. :D
