Bizarre Generated Code from Millface Operation?
I generated a simple surfacing toolpath for my new CNC router using the mill surfacing operation. The area is 30" square. The generated gcode is 1053MB, too large to attach. As far as I can see, it shouldn't contain more than a few hundred lines of gcode. I cancelled the run after it had completed a single pass over the wasteboard and was very close. A pocket operation of the same size generates a file of the same size. What is going on here? This seems like a serious bug.
Thanks in advance,
Frank
Thanks in advance,
Frank
- SurfacingTest.FCStd
- (217.78 KiB) Downloaded 30 times
Re: Bizarre Generated Code from Surfacing Operation?
using the current 0.19 (freecad-daily PPA), it's nowhere near 1 GB:
can you post a screenshot / how it looks in the simulator?
-rw-rw-r-- 1 iacobs iacobs 1.1M Apr 9 20:44 SurfacingTest.nc
I watched the simulation and stopped it after it had repeated the same path at least 8 times. The path is like this:
There are 28094 lines in the generated code. The nightly is from 08Apr2020. As noted in the setup data copied from the about box, I'm running 64-bit Windows 10, fully patched.
.There are 28094 lines in the generated code. The nightly is from 08Apr2020. As noted in the setup data copied from the about box, I'm running 64-bit Windows 10, fully patched.
- roerich_64
Hi falviani,
i switched back from 'ZigZagOffset' to 'ZigZag': Now no problem:
Bests
Walter
(Exported by FreeCAD)
(Post Processor: grbl_post)
(Output Time:2020-04-09 21:32:05.728467)
(Begin preamble)
G17 G90
G21
(Begin operation: Fixture)
(Path: Fixture)
G54
(Finish operation: Fixture)
(Begin operation: T9: Surfacing)
(Path: T9: Surfacing)
(T9: Surfacing)
(Begin toolchange)
(M6 T9.0)
M3 S22000.0
(Finish operation: T9: Surfacing)
(Begin operation: MillFace)
(Path: MillFace)
(MillFace)
G0 Z6.000
G0 X749.300 Y12.700
G0 Z4.000
G1 X749.300 Y12.700 Z-0.500 F180.000
G1 X749.300 Y30.661 Z-0.500 F660.000
G1 X731.339 Y12.700 Z-0.500 F660.000
G1 X713.379 Y12.700 Z-0.500 F660.000
G1 X749.300 Y48.621 Z-0.500 F660.000
G1 X749.300 Y66.582 Z-0.500 F660.000
G1 X695.418 Y12.700 Z-0.500 F660.000
G1 X677.458 Y12.700 Z-0.500 F660.000
G1 X749.300 Y84.542 Z-0.500 F660.000
G1 X749.300 Y102.503 Z-0.500 F660.000
G1 X659.497 Y12.700 Z-0.500 F660.000
G1 X641.537 Y12.700 Z-0.500 F660.000
G1 X749.300 Y120.463 Z-0.500 F660.000
G1 X749.300 Y138.424 Z-0.500 F660.000
G1 X623.576 Y12.700 Z-0.500 F660.000
G1 X605.616 Y12.700 Z-0.500 F660.000
G1 X749.300 Y156.384 Z-0.500 F660.000
G1 X749.300 Y174.345 Z-0.500 F660.000
G1 X587.655 Y12.700 Z-0.500 F660.000
G1 X569.695 Y12.700 Z-0.500 F660.000
G1 X749.300 Y192.305 Z-0.500 F660.000
G1 X749.300 Y210.266 Z-0.500 F660.000
G1 X551.734 Y12.700 Z-0.500 F660.000
G1 X533.774 Y12.700 Z-0.500 F660.000
G1 X749.300 Y228.226 Z-0.500 F660.000
G1 X749.300 Y246.187 Z-0.500 F660.000
G1 X515.813 Y12.700 Z-0.500 F660.000
G1 X497.853 Y12.700 Z-0.500 F660.000
G1 X749.300 Y264.147 Z-0.500 F660.000
G1 X749.300 Y282.108 Z-0.500 F660.000
G1 X479.892 Y12.700 Z-0.500 F660.000
G1 X461.932 Y12.700 Z-0.500 F660.000
G1 X749.300 Y300.068 Z-0.500 F660.000
G1 X749.300 Y318.029 Z-0.500 F660.000
G1 X443.971 Y12.700 Z-0.500 F660.000
G1 X426.011 Y12.700 Z-0.500 F660.000
G1 X749.300 Y335.989 Z-0.500 F660.000
G1 X749.300 Y353.950 Z-0.500 F660.000
G1 X408.050 Y12.700 Z-0.500 F660.000
G1 X390.090 Y12.700 Z-0.500 F660.000
G1 X749.300 Y371.910 Z-0.500 F660.000
G1 X749.300 Y389.871 Z-0.500 F660.000
G1 X372.129 Y12.700 Z-0.500 F660.000
G1 X354.169 Y12.700 Z-0.500 F660.000
G1 X749.300 Y407.831 Z-0.500 F660.000
G1 X749.300 Y425.792 Z-0.500 F660.000
G1 X336.208 Y12.700 Z-0.500 F660.000
G1 X318.248 Y12.700 Z-0.500 F660.000
G1 X749.300 Y443.752 Z-0.500 F660.000
G1 X749.300 Y461.713 Z-0.500 F660.000
G1 X300.287 Y12.700 Z-0.500 F660.000
G1 X282.327 Y12.700 Z-0.500 F660.000
G1 X749.300 Y479.673 Z-0.500 F660.000
G1 X749.300 Y497.634 Z-0.500 F660.000
G1 X264.366 Y12.700 Z-0.500 F660.000
G1 X246.406 Y12.700 Z-0.500 F660.000
G1 X749.300 Y515.594 Z-0.500 F660.000
G1 X749.300 Y533.555 Z-0.500 F660.000
G1 X228.445 Y12.700 Z-0.500 F660.000
G1 X210.485 Y12.700 Z-0.500 F660.000
G1 X749.300 Y551.515 Z-0.500 F660.000
G1 X749.300 Y569.476 Z-0.500 F660.000
G1 X192.524 Y12.700 Z-0.500 F660.000
G1 X174.564 Y12.700 Z-0.500 F660.000
G1 X749.300 Y587.436 Z-0.500 F660.000
G1 X749.300 Y605.397 Z-0.500 F660.000
G1 X156.603 Y12.700 Z-0.500 F660.000
G1 X138.643 Y12.700 Z-0.500 F660.000
G1 X749.300 Y623.357 Z-0.500 F660.000
G1 X749.300 Y641.318 Z-0.500 F660.000
G1 X120.682 Y12.700 Z-0.500 F660.000
G1 X102.722 Y12.700 Z-0.500 F660.000
G1 X749.300 Y659.278 Z-0.500 F660.000
G1 X749.300 Y677.239 Z-0.500 F660.000
G1 X84.761 Y12.700 Z-0.500 F660.000
G1 X66.801 Y12.700 Z-0.500 F660.000
G1 X749.300 Y695.199 Z-0.500 F660.000
G1 X749.300 Y713.160 Z-0.500 F660.000
G1 X48.840 Y12.700 Z-0.500 F660.000
G1 X30.880 Y12.700 Z-0.500 F660.000
G1 X749.300 Y731.120 Z-0.500 F660.000
G1 X749.300 Y749.081 Z-0.500 F660.000
G1 X12.919 Y12.700 Z-0.500 F660.000
G1 X12.700 Y12.700 Z-0.500 F660.000
G1 X12.700 Y30.442 Z-0.500 F660.000
G1 X731.558 Y749.300 Z-0.500 F660.000
G1 X713.598 Y749.300 Z-0.500 F660.000
G1 X12.700 Y48.402 Z-0.500 F660.000
G1 X12.700 Y66.363 Z-0.500 F660.000
G1 X695.637 Y749.300 Z-0.500 F660.000
G1 X677.677 Y749.300 Z-0.500 F660.000
G1 X12.700 Y84.323 Z-0.500 F660.000
G1 X12.700 Y102.284 Z-0.500 F660.000
G1 X659.716 Y749.300 Z-0.500 F660.000
G1 X641.756 Y749.300 Z-0.500 F660.000
G1 X12.700 Y120.244 Z-0.500 F660.000
G1 X12.700 Y138.205 Z-0.500 F660.000
G1 X623.795 Y749.300 Z-0.500 F660.000
G1 X605.835 Y749.300 Z-0.500 F660.000
G1 X12.700 Y156.165 Z-0.500 F660.000
G1 X12.700 Y174.126 Z-0.500 F660.000
G1 X587.874 Y749.300 Z-0.500 F660.000
G1 X569.914 Y749.300 Z-0.500 F660.000
G1 X12.700 Y192.086 Z-0.500 F660.000
G1 X12.700 Y210.047 Z-0.500 F660.000
G1 X551.953 Y749.300 Z-0.500 F660.000
G1 X533.993 Y749.300 Z-0.500 F660.000
G1 X12.700 Y228.007 Z-0.500 F660.000
G1 X12.700 Y245.968 Z-0.500 F660.000
G1 X516.032 Y749.300 Z-0.500 F660.000
G1 X498.072 Y749.300 Z-0.500 F660.000
G1 X12.700 Y263.928 Z-0.500 F660.000
G1 X12.700 Y281.889 Z-0.500 F660.000
G1 X480.111 Y749.300 Z-0.500 F660.000
G1 X462.151 Y749.300 Z-0.500 F660.000
G1 X12.700 Y299.849 Z-0.500 F660.000
G1 X12.700 Y317.810 Z-0.500 F660.000
G1 X444.190 Y749.300 Z-0.500 F660.000
G1 X426.230 Y749.300 Z-0.500 F660.000
G1 X12.700 Y335.770 Z-0.500 F660.000
G1 X12.700 Y353.731 Z-0.500 F660.000
G1 X408.269 Y749.300 Z-0.500 F660.000
G1 X390.309 Y749.300 Z-0.500 F660.000
G1 X12.700 Y371.691 Z-0.500 F660.000
G1 X12.700 Y389.652 Z-0.500 F660.000
G1 X372.348 Y749.300 Z-0.500 F660.000
G1 X354.388 Y749.300 Z-0.500 F660.000
G1 X12.700 Y407.612 Z-0.500 F660.000
G1 X12.700 Y425.573 Z-0.500 F660.000
G1 X336.427 Y749.300 Z-0.500 F660.000
G1 X318.467 Y749.300 Z-0.500 F660.000
G1 X12.700 Y443.533 Z-0.500 F660.000
G1 X12.700 Y461.494 Z-0.500 F660.000
G1 X300.506 Y749.300 Z-0.500 F660.000
G1 X282.546 Y749.300 Z-0.500 F660.000
G1 X12.700 Y479.454 Z-0.500 F660.000
G1 X12.700 Y497.415 Z-0.500 F660.000
G1 X264.585 Y749.300 Z-0.500 F660.000
G1 X246.625 Y749.300 Z-0.500 F660.000
G1 X12.700 Y515.375 Z-0.500 F660.000
G1 X12.700 Y533.336 Z-0.500 F660.000
G1 X228.664 Y749.300 Z-0.500 F660.000
G1 X210.704 Y749.300 Z-0.500 F660.000
G1 X12.700 Y551.296 Z-0.500 F660.000
G1 X12.700 Y569.257 Z-0.500 F660.000
G1 X192.743 Y749.300 Z-0.500 F660.000
G1 X174.783 Y749.300 Z-0.500 F660.000
G1 X12.700 Y587.217 Z-0.500 F660.000
G1 X12.700 Y605.178 Z-0.500 F660.000
G1 X156.822 Y749.300 Z-0.500 F660.000
G1 X138.862 Y749.300 Z-0.500 F660.000
G1 X12.700 Y623.138 Z-0.500 F660.000
G1 X12.700 Y641.099 Z-0.500 F660.000
G1 X120.901 Y749.300 Z-0.500 F660.000
G1 X102.941 Y749.300 Z-0.500 F660.000
G1 X12.700 Y659.059 Z-0.500 F660.000
G1 X12.700 Y677.020 Z-0.500 F660.000
G1 X84.980 Y749.300 Z-0.500 F660.000
G1 X67.020 Y749.300 Z-0.500 F660.000
G1 X12.700 Y694.980 Z-0.500 F660.000
G1 X12.700 Y712.941 Z-0.500 F660.000
G1 X49.059 Y749.300 Z-0.500 F660.000
G1 X31.099 Y749.300 Z-0.500 F660.000
G1 X12.700 Y730.901 Z-0.500 F660.000
G1 X12.700 Y748.862 Z-0.500 F660.000
G1 X12.700 Y749.300 Z-0.500 F660.000
G1 X13.138 Y749.300 Z-0.500 F660.000
G0 Z6.000
(Finish operation: MillFace)
(Begin postamble)
M5
G17 G90
M2
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.19.20406 (Git) AppImage
Hash: bb45a2b01f9aafeae00cdf60c87b43fc36ad28ad
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Walter
Die Liebe wird siegen, denn sie ist unzerstörbar
Hi Frank,
i can't reproduce that...
If i export your Job to an gcode file, the filesize is about 7 KiB and a few lines only...
- SurfacingTest.nc.txt
- (6.89 KiB) Downloaded 22 times
Gruß Herbert
Please add your full FreeCAD infos, see http://forum.freecadweb.org/viewtopic.php?f=3&t=2264.
You may consider renaming the topic to contain "MillFace" instead of "Surfacing", because the latter suggests that it's about 3Dsurface.
Trying to export runs already for several minutes; still trying to show the post process preview window.
Sorry - I had copied it to the clipboard but forgot to paste
OS: Windows 10 (10.0)
Version: 0.19.20477 (Git)
Hash: 7d8ab175a68e476427e6e337fe3099b52da49dc8
Python version: 3.6.8
Qt version: 5.12.1
Qt version: 5.12.1
Re: Bizarre Generated Code from Millface Operation?
Finally finished. The output contains 28000 lines. After adding the argument --no-show-editor the number of lines is reduced to 200 lines. Can you retry with adding this parameter?
- sliptonic
This might be a red herring but I noticed a weird effect yesterday that I've not had time to investigate. I was doing a contour operation and added 1mm of extra offset. Instead I got something like 10000000000mm and FreeCAD crashed. I repeated the same thing twice. When I entered the value through the data tab property, it worked fine but in the task panel I'd get bogus values.
You might make sure you're not getting something like a step down of some absurdly small amount so it's generating hundreds of passes over the same area.
Changing the parameter seems to have triggered a recompute.
Please try loading the file and perform a full recompute and report back if that solves the issue.
