Control over individual paths: is there a better way?
burgerking
Post by burgerking »
Hi!
Thanks again to this community for the help so far. This post is a continuation of: https://forum.freecadweb.org/viewtopic. ... 5&start=10
I managed to solve my particular problem, but it is not ideal.
EARLIER APPROACH: I am able to get the basic GCODE from GCodeStr = sPath.toGCode(), but I do not know how to insert custom commands (like those below) into this, and it gives me no control over the individual paths. As I mentioned, when using the toGCode() method, adjacent paths alternate cutting directions.
NEW APPROACH: Basically, I generate a new unique path for each new offset. This clutters the FC model window, and I assume is really bad with regards to speed of processing. Here is the code:
With a sketch 'Sketch':
import FreeCAD
import FreeCAD as App
import Path, PathCommands
import numpy as np
Fobj = FreeCAD.activeDocument().addObject('Path::FeatureArea','FeatureArea')
Fobj.Sources = [ FreeCAD.activeDocument().Sketch, ]
gCode_out = []
offsets = np.linspace(1.1, 2.2, 15)
def genGcode(offsets, Fobj, gCode_out):
# Generate a path around the shape for each offset, and make sure we output GCODE in the correct format.
	for oset_counter, oset in enumerate(offsets):
		n = oset#/1000.0
		Fobj.Offset = n
		Fobj.ExtraPass = 0
		Fobj.JoinType = u"Miter"
		Fobj.MiterLimit = 10.00
		Fobj.Shape
		App.activeDocument().recompute(None,True,True)
		pArea = Path.Area()
		pArea.add(Fobj.Shape)
		sPath = Path.fromShapes(pArea.getShape(), orientation=1)
		Path.show(sPath)
		g1_counter = 0
		g2_counter = 0
		g3_counter = 0
		for i in sPath.Commands:
			if i.Name=='G0':
				if i.Parameters!={}:
					gCode_out.append('BEAMOFF')
					gCode_out.append(i.toGCode())
			if i.Name=='G1':
				if g1_counter==0:
					gCode_out.append('CALL_BLASTAWAY')
				g1_counter+=1
			if i.Name=='G2':
				if g2_counter==0:
				g2_counter+=1
			if i.Name=='G3':
				if g3_counter==0:
				g3_counter+=1
			if i.Name=='G90':
				pass
	return gCode_out
gCode_out = genGcode(offsets, Fobj, gCode_out)
Is there a better way? I am new enough to python that I assume this is a bad hack. At very least, can all these paths be reconsolidated in some way?
Thanks!
