Heidenhain Postprocessor
- sliptonic
Re: Heidenhain Postprocessor
merged into master on May 8th.
https://github.com/FreeCAD/FreeCAD/pull/3445
If it is merged, shouldn't it occur in the current distribution? Mine is from 2020/06/17.
OS: macOS High Sierra (10.13)
Version: 0.19.21671 (Git)
Hash: f05253f882b336f56aae32593faa5676fd5aafdd
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
Qt version: 5.12.5
OCC version: 7.4.0
Hi @Zibibbo84, heads up. According to LGTM there is a redundant assignment in code you introduced.Zibibbo84 wrote:
See https://lgtm.com/projects/g/FreeCAD/Fre ... atmap#L803
Here is the code on github:
https://github.com/FreeCAD/FreeCAD/comm ... 2014ffR805
# set the appropriate zero and direction of angle
# with X axis zero have the Y+ direction
if pol_Axis == "X":
pol_Angle = 90 - pol_Angle
# with Y axis zero have the Z+ direction
elif pol_Axis == "Y":
pol_Angle = pol_Angle
# with Z axis zero have the X+ direction
elif pol_Axis == "Z":
Hello, I found this code before I came across yours, maybe it will help somehow.
https://gist.github.com/TurBoss/a9a0737 ... -heiden-py
Thank you very much for your work.
I only have one problem
Neither one can drill through the cycle and writes some madness there.
Hi and welcome to the forum, thanks for the contribution!
I don't think we can use this directly, but it can serve as an example in the discussion of how to unify the postprocessors.
what's the problem?WilomanCZ wrote: ↑Mon Feb 15, 2021 5:59 pm Hello, I found this code before I came across yours, maybe it will help somehow.
can you give me an example
It do not generate drilling in normal HaidenHain cycle, i don't think the what it generate will actually work in real CNC machine, but i can be wrong.Zibibbo84 wrote: ↑Mon Feb 15, 2021 10:30 pmwhat's the problem?WilomanCZ wrote: ↑Mon Feb 15, 2021 5:59 pm Hello, I found this code before I came across yours, maybe it will help somehow.
PS: What version is with LBLs? And how activate it? Thanks
I think best is all thinks what i same for maby 2-xx holes or some shape is best to call it from LBL, beacuse you always know if one layer is ok so all others is good too and program will be smaller too.
In our company, they program everything that goes into LBL, even threaded cutters (milled), or even hole depths if there are more of them and it is also with drilling with slower speeds of the first few mm
I want use it just for teach myself programing in PC for CNC machine. But i need HaidenHain no ISO like is in FreeCAD
LBLs can be activated with post arguments, follow the quote belowWilomanCZ wrote: ↑Wed Feb 24, 2021 4:10 pm It do not generate drilling in normal HaidenHain cycle, i don't think the what it generate will actually work in real CNC machine, but i can be wrong.
For cycles i haven't write code to replace it with LBLs they work only with multi level milling.
I don't know if i have time to implement this thing due to my job.
If you need you can do it by replacing CYCL DEF with a LBL and CYCL CALL with a CALL LBL using incremental values of Z.
I know it's an horrible solution but i can't do more now.
If you have a version of Heidenhain that have cycles 200 you can use the 205 to have a slower speed for some mm, i use it.
Any update on the post processor ?
Best regards
Best regards
Hi Zibibbo84, can you share the file where you tried the postprocessor? Unfortunately i keep getting this error when i try myself: '_TempObject' object has no attribute 'Proxy'.
