Path 3DSurface loading error
mpetrasinovic
Postby mpetrasinovic » Sat May 16, 2020 10:53 am
I could not use 3DSurface because I get the following error on command activation. After that, surface selection those not work.
Surfacing Select Mode
  File "C:\Program Files\FreeCAD_0.19.21068_x64_LP_12.1.2_PY3QT5-WinVS2015\Mod\Path\PathScripts\PathOpGui.py", line 104, in setEdit
    self.setupTaskPanel(TaskPanel(vobj.Object, self.deleteObjectsOnReject(), page, selection))
  File "C:\Program Files\FreeCAD_0.19.21068_x64_LP_12.1.2_PY3QT5-WinVS2015\Mod\Path\PathScripts\PathOpGui.py", line 115, in setupTaskPanel
    panel.setupUi()
  File "C:\Program Files\FreeCAD_0.19.21068_x64_LP_12.1.2_PY3QT5-WinVS2015\Mod\Path\PathScripts\PathOpGui.py", line 1058, in setupUi
    page.clearBase()
  File "C:\Program Files\FreeCAD_0.19.21068_x64_LP_12.1.2_PY3QT5-WinVS2015\Mod\Path\PathScripts\PathOpGui.py", line 543, in clearBase
    self.updatePanelVisibility('Operation', self.obj)
  File "C:\Program Files\FreeCAD_0.19.21068_x64_LP_12.1.2_PY3QT5-WinVS2015\Mod\Path\PathScripts\PathOpGui.py", line 404, in updatePanelVisibility
    page.updateVisibility(obj)
<class 'TypeError'>: updateVisibility() takes 1 positional argument but 2 were given
OS: Windows 10 (10.0)
Version: 0.19.21068 (Git)
Hash: 92fe9adebbff910c5a10d6230785a6b58935b677
Python version: 3.6.8
Qt version: 5.12.1
Locale: Serbian/Serbia (sr_RS)
Syres
Re: Path 3DSurface loading error
Postby Syres » Sun May 17, 2020 6:16 am
Confirmed using:
OS: Windows 7 SP 1 (6.1)
Version: 0.19.21097 (Git)
Hash: a5ab09aa0941cc945e59848897b160f8cbfc0831
Qt version: 5.12.1
I think line 404 of src\Mod\Path\PathScripts\PathOpGui.py should be changed from:
to:
                            page.updateVisibility()
Give it a try, it appears to work correctly for me after the change.
Russ4262
Postby Russ4262 » Sun May 17, 2020 8:48 pm
My error. I will try to get a PR for this, soon.
Russ
Russ4262
Postby Russ4262 » Mon May 18, 2020 2:29 am
Evening,
The GitHub user, gwicke, has an active PR for this fix, [path] Small fix in PathOpGui #3477.
Russ
mpetrasinovic
Postby mpetrasinovic » Mon May 18, 2020 7:33 am
That was fast!
Thank you very much.
