Yes, I know. But I meant something different: suppose your circular shape is produced by using one or more boolean operations with a cone cutting another body. You don't know exactly at what height the cone cuts you body. So you have to calculate somehow the diameter in order to move the "clone" of an appropriate distance.RatonLaveur wrote: ↑Wed May 20, 2020 7:30 pmFirst thing that PathWB Job does, is make a clone of your model. So no problem moving that around. All ops are based on the clone.Giulio Buccini wrote: ↑Wed May 20, 2020 7:01 pm Furthermore, it is not a not so immediate operation when your circle is produced by a sequence of boolean operations, so you don't know exactly the circle size and where is his center.
Furthermore, the field in the graphical interface accepts max two decimal digits.
