Prevent automatic list fill
- mpetrasinovic
Is it possible to prevent an automatic fill of the list (Base Geometry) with all circular holes eligible for the operation from the model within Drilling operation?
- sliptonic
Re: Prevent automatic list fill
If you select holes before creating the operation, it should only use the selection. If you select nothing, it will autodetect drillable holes but you can always clear the list.
- mpetrasinovic
How to clear the list (Base Geometry) within Drilling operation? Probably a stupid question
What you mean by select holes before creating the operation? If I select a circular edge or cylindrical face from the 3D view it does not use the selection.
- sliptonic
Select the rows in the geometry tab. (Not the tick selection, you actually have to select the rows. Or select one row and then do Ctrl+Ampetrasinovic wrote: ↑Mon Jun 01, 2020 5:08 pm How to clear the list (Base Geometry) within Drilling operation?
Then use the 'remove' button
Hmm. This seems to be a regression. It doesn't work for me either. I'm not sure when we lost that.What you mean by select holes before creating the operation? If I select a circular edge or cylindrical face from the 3D view it does not use the selection.
- mpetrasinovic
I will try like that, but what caught my attention is the Reset button, my opinion is that there should be Recognize and Clear buttons instead. For me, this Reset button was misleading (because it is Clear than Recognize it is not reset of the list).
I hope that this will find way back in master.
