Path WB@ no Z jog
freman
Path WB@ no Z jog
Postby freman » Mon Jul 13, 2020 2:47 pm
I need to move z=0 down a few mm.
In job setup I have a set of turquoise buttons to jog X and Y origin and a button to set z=0 to some feature on the model. But no means to jog z origin.
I need to set z=0 3mm down from the highest point in the model. How can I do this ?
TIA.
OS: Fedora 31 (Thirty One) (LXDE/LXDE)
Version: 0.19.21806 (Git)
Hash: 68b98f5ffead8d90b2e9f6308ca55acefd758352
Python version: 3.7.7
Qt version: 5.13.2
GeneFC
Re: Path WB@ no Z jog
Postby GeneFC » Mon Jul 13, 2020 4:01 pm
Moved to Path forum.
RatonLaveur
Postby RatonLaveur » Mon Jul 13, 2020 7:43 pm
This is one of the reasons i like creating a datum point that i then set the reference to.
In your case, my solution is a workaround. In many cases it enables accurate and parametric positioning of the ref.
freman
Postby freman » Mon Jul 13, 2020 8:15 pm
Thanks, I had not thought of using a datum point.
I've set one at about the right spot but when I go to edit Setup for the job it does not seem visible, so I can't use it.
What am I missing?
evoud3
Postby evoud3 » Tue Jul 14, 2020 3:44 pm
My workaround is (temporarily) decreasing the stock size in the Z direction, then selecting one of it's vertices/corners and clicking 'Set Origin'. You might have to untick 'Link Stock and Model' for this to work. After setting the origin, you can increase the stock size again.
You might be able to edit the coordinates of the Origin point in one of the properties tabs as well.
sliptonic
Postby sliptonic » Tue Jul 14, 2020 4:58 pm
The GUI tools for moving the model just adjust the placement property of the model clone. You can always adjust that placement manually in the property pane, including the Z position.
freman
Postby freman » Tue Jul 14, 2020 5:16 pm
Thanks Slip' , it is not really obvious what is being adjusted from within the UI, so that tip is very helpful.
It's never been problem for me before because I've always been able to find a convenient point on the part but there is not reason why that would always be possible.
Ultimately it would be nice to have two more buttons. I don't see why Z got left out of this.
Anyway that trick solves my immediate problem. Thanks.
RatonLaveur
Postby RatonLaveur » Wed Jul 15, 2020 6:33 am
I have never had an issue seeing and referencing the datums produced by the WorkFeatures Workbench. Perhaps the actual datums from Part Design are different entities.
