3d pocker troubles
xf3qc
3d pocker troubles
Postby xf3qc » Sun Aug 02, 2020 6:15 am
using 0.19 now., but always got this same issue, when making a 3d pocket,
only a limited cross section is generated, not starting at top, nor reaching bottom.
base.FCStd
(37.2 KiB) Downloaded 4 times
Re: 3d pocker troubles
Postby chrisb » Sun Aug 02, 2020 8:22 am
Please add your full FreeCAD infos. We don't even know which OS you use.
herbk
Postby herbk » Sun Aug 02, 2020 9:14 am
if you use 3D Pocket OP your part have to have a bottom, so you have to ad a helper pad.
base_herbk.FCStd
(47.65 KiB) Downloaded 3 times
Gruß Herbert
xf3qc
Postby xf3qc » Sun Aug 02, 2020 8:37 pm
will mention from now.
0.19 Revison 22044 with your fix - pull/3706
had this issue with 3d pockets in all versions, should have asked earlier :x
Thank you herbk!
Going to try again now.
freman
Postby freman » Thu Aug 06, 2020 2:28 pm
Notwithstanding herb's advice, you will need to tell it to over run the boundary. There are several essential parameters which need to be set from the treeview, since they are not integrated into the GUI dialogue yet.
from memory there is one like Enforce boundary which you need to flip to false. Currently your paths don't let the outer edge of the tool go outside the outline of the frame and to get down the sides you need to go a full tool width outside the boundary. Herb's helper body is a way around that but I prefer the model to really model the object unless that cannot be avoided.
Requests for version info refer to the Help menu | About , which has a copy to clipboard button. This gives hook line and sinker about what you are running and on what platform.
