This. Usually happens when I copy/move models/parts/sketches in between files back and forth... could that cause "forbidden links" ? But then, shouldn't the problem(forbidden link) persist even after restarting freecad?
path stops outputting g-code
Re: path stops outputting g-code
I don't care very much how erroneous models behave, even if it is sometimes seemingly correct. If a faulty model can throw FreeCAD off track, then this is an error. And of course FreeCAD should help avoiding such models.
Did you try the fixed model? That may be more interesting than the consequences of editing a faulty one.
Can't recreate for now.chrisb wrote: ↑Wed Aug 19, 2020 11:17 pm I don't care very much how erroneous models behave, even if it is sometimes seemingly correct. If a faulty model can throw FreeCAD off track, then this is an error. And of course FreeCAD should help avoiding such models.
I never actually looked at/used a dependency graph
wouldn't know erroneous model from a proper one.
Will figure this out hopefully and report.
The Dependency Graph is not "magic", but it oftens shows errors as red connecting lines. If you see such a line, it usually means your model is broken in some manner. That does not mean you will automatically see a failure, but the model is definitely fragile at that point.
It can also be useful to see if you are following "best practices", but you need to know what those are in the first place. If you do, you probably will already be avoiding "bad practices."
Gene
Free Select
Profiling Select Mode
Free Select
Path workbench deactivated
Path workbench activated
post: linuxcnc(/home/mandd/Documents/cncdriveblue/default.ngc, --no-header --no-show-editor --no-tlo)
linuxcnc_post gcode postprocessor loaded.
Show editor = 0
postprocessing...
done postprocessing.
Show editor = 0
postprocessing...
Running the Python command 'Path_Post' failed:
File "/home/mandd/freebuild1/freecad-build/Mod/Path/PathScripts/PathPost.py", line 397, in Activated
(fail, rc) = self.exportObjectsWith(finalpostlist, job)
File "/home/mandd/freebuild1/freecad-build/Mod/Path/PathScripts/PathPost.py", line 212, in exportObjectsWith
gcode = processor.export(objs, filename, postArgs)
File "/home/mandd/freebuild1/freecad-build/Mod/Path/PathScripts/PathPostProcessor.py", line 102, in export
return self.script.export(obj, filename, args)
File "/home/mandd/freebuild1/freecad-build/Mod/Path/PathScripts/post/linuxcnc_post.py", line 196, in export
job = PathUtils.findParentJob(obj)
File "/home/mandd/freebuild1/freecad-build/Mod/Path/PathScripts/PathUtils.py", line 443, in findParentJob
if hasattr(i, 'Proxy') and isinstance(i.Proxy, PathScripts.PathJob.ObjectJob):
Cannot access attribute 'Proxy' of deleted object
****FreeCAD restarted"
mandd@xbox1:~$ /home/mandd/freebuild1/freecad-build/bin/FreeCAD
FreeCAD 0.19, Libs: 0.19R22279 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
connect failed: No such file or directory
Show editor = 0
postprocessing...
there is goes again. Restarted. Works.
- blank_brackets.FCStd
- (205.43 KiB) Downloaded 35 times
Did you have in the same FreeCAD session any other Path related error before?
maybe yes, there is this other problem that is probably caused by my radical behavior so I didn't mention it yet.
there are 3 operations that have Base Geometry selected from:
square_style1_4hole_120mm Solid (which has a Placement of X: 240mm Y: 245mm)
if I change that placement to say: X: 227mm Y: 245mm
Path now fails with:
<Path.Area> Area.cpp(1318): project failed
<Path.Area> Area.cpp(1460): empty projection
But starts working again at other Placement coordinates (randomly).
Not sure if related
- empty.FCStd
- (216.53 KiB) Downloaded 29 times
If you change the placement you may have to go into the job and adjust the stock too.
