Ticket #4433 - profile operation cut side reset
xf3qc
Postby xf3qc » Fri Aug 14, 2020 11:10 pm
when re-selecting/changing geometry on existing profile operation, cut side is reset to "outside" even if it was set to "inside" prior.
0.19 Rev 22044
Reason: Added ticket number to thread title
Re: profile operation cut side reset
Postby chrisb » Sat Aug 15, 2020 5:21 am
I cannot confirm. Please load the attached file, double click one of the profiles, cut side stays inside.
OS: macOS High Sierra (10.13)
Version: 0.19.22246 (Git)
Hash: abd18ff88f7682e9b1160c36bb785b14a33473ef
Python version: 3.8.5
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
profileInside.FCStd
(19.13 KiB) Downloaded 8 times
xf3qc
Postby xf3qc » Sat Aug 15, 2020 5:46 am
Qt version: 5.12.5
OCC version: 7.4.0
OS: Debian GNU/Linux bullseye/sid (XFCE/lightdm-xsession)
Version: 0.19.22044 (Git)
Build type: Unknown
Hash: f5f9eb7161a07caaaf797032cf4849a591d0970d
Python version: 3.8.4
Qt version: 5.14.2
OCC version: 7.4.0
Postby chrisb » Sat Aug 15, 2020 6:04 am
Fancy colors, I almost didn't recognize that it is FreeCAD.
I can reproduce the issue. The cut side is reset when the last edge is removed.
herbk
Postby herbk » Sat Aug 15, 2020 9:02 am
OK... but is it realy an issue?
It is not only the cut side reseted, the whole OP is deleted (you can see the the green line for the path disapers). Contour ops are "closed loop" ops, if you delete one of the edges to mill, the OP isn't closed and get's invalid.
That's my assessment to this behavior...
Gruß Herbert
memfis
Postby memfis » Sat Aug 15, 2020 9:17 am
And I confirm and have previously reported it.
Postby chrisb » Sat Aug 15, 2020 10:38 am
Meanwhile see here:
xf3qc
Postby xf3qc » Sat Aug 15, 2020 5:23 pm
so would it be appropriate to post this as issue on https://tracker.freecadweb.org now?
Postby chrisb » Sat Aug 15, 2020 9:13 pm
I would like to hear some more voices before creating a ticket. As herbk pointed out, it may be sensible to reset the operation if all edges are removed.
xf3qc
Postby xf3qc » Sun Aug 16, 2020 12:31 am
ooops.. missed your reply initially.
1. User assumes that the OP is already configured and not realizing that "Cut side" resets.
Happened to me several times, and still keeps on happening even now that I am aware of this. It's easy not to notice until it's actually milling.
2. If replacing geometry completely = "whole OP is deleted" shouldn't other OP settings reset as well (like direction)?
